I want to configure a SIM7600G-H-M2 4G HAT card on home assistant but I can’t do the routing here is my configuration and the error that I have
`Texte préformaté` ifconfig
docker0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.30.232.1 netmask 255.255.254.0 broadcast 172.30.233.255
inet6 fe80::e8b3:2aff:fe5a:faac prefixlen 64 scopeid 0x20<link>
ether ea:b3:2a:5a:fa:ac txqueuelen 0 (Ethernet)
RX packets 67 bytes 6969 (6.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 248 bytes 79064 (77.2 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
end0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.133 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::4777:ec0b:f474:e2b3 prefixlen 64 scopeid 0x20<link>
inet6 2a01:cb05:81ec:f00:6692:e189:c77a:44a2 prefixlen 64 scopeid 0x0<global>
ether 2c:cf:67:87:8d:c5 txqueuelen 1000 (Ethernet)
RX packets 1759 bytes 583671 (569.9 KiB)
RX errors 0 dropped 19 overruns 0 frame 0
TX packets 3019 bytes 712113 (695.4 KiB)
device interrupt 107
enu1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.225.28 netmask 255.255.255.0 broadcast 192.168.225.255
inet6 fe80::839a:8b38:4658:6436 prefixlen 64 scopeid 0x20<link>
ether d6:c2:e6:72:9f:b7 txqueuelen 1000 (Ethernet)
RX packets 28 bytes 2711 (2.6 KiB)
TX packets 55 bytes 9883 (9.6 KiB)
hassio: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.30.32.1 netmask 255.255.254.0 broadcast 172.30.33.255
inet6 fe80::dcb5:5fff:fe43:b2cb prefixlen 64 scopeid 0x20<link>
ether de:b5:5f:43:b2:cb txqueuelen 0 (Ethernet)
RX packets 3501 bytes 796631 (777.9 KiB)
TX packets 3179 bytes 902581 (881.4 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 104 bytes 18826 (18.3 KiB)
TX packets 104 bytes 18826 (18.3 KiB)
veth439ee97: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::28f3:88ff:feb1:f2e9 prefixlen 64 scopeid 0x20<link>
ether 2a:f3:88:b1:f2:e9 txqueuelen 0 (Ethernet)
RX packets 1342 bytes 134887 (131.7 KiB)
TX packets 982 bytes 433677 (423.5 KiB)
veth70510bb: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::14cc:3fff:feba:974c prefixlen 64 scopeid 0x20<link>
ether 16:cc:3f:ba:97:4c txqueuelen 0 (Ethernet)
RX packets 26 bytes 3708 (3.6 KiB)
TX packets 387 bytes 81386 (79.4 KiB)
vetha6e2106: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::a0b4:93ff:fe13:598d prefixlen 64 scopeid 0x20<link>
ether a2:b4:93:13:59:8d txqueuelen 0 (Ethernet)
RX packets 3 bytes 126 (126.0 B)
TX packets 335 bytes 68508 (66.9 KiB)
vetha90b7bf: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::e8ff:4aff:fec4:61b2 prefixlen 64 scopeid 0x20<link>
ether ea:ff:4a:c4:61:b2 txqueuelen 0 (Ethernet)
RX packets 67 bytes 7907 (7.7 KiB)
TX packets 323 bytes 94332 (92.1 KiB)
vethe4eb83c: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::88db:a0ff:fe07:8c0a prefixlen 64 scopeid 0x20<link>
ether 8a:db:a0:07:8c:0a txqueuelen 0 (Ethernet)
TX packets 419 bytes 82866 (80.9 KiB)
vethe7ad975: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::f070:74ff:fee1:752 prefixlen 64 scopeid 0x20<link>
ether f2:70:74:e1:07:52 txqueuelen 0 (Ethernet)
RX packets 950 bytes 618753 (604.2 KiB)
TX packets 1431 bytes 310680 (303.3 KiB)
vethe8c0633: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::84ed:b7ff:fe4b:f5d7 prefixlen 64 scopeid 0x20<link>
ether 86:ed:b7:4b:f5:d7 txqueuelen 0 (Ethernet)
RX packets 58 bytes 5784 (5.6 KiB)
TX packets 196 bytes 153549 (149.9 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 2c:cf:67:87:8d:c6 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
ztwdjmset2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 2800
inet 192.168.192.103 netmask 255.255.255.0 broadcast 192.168.192.255
inet6 fe80::4cb1:1dff:fe45:bd38 prefixlen 64 scopeid 0x20<link>
ether 4e:b1:1d:45:bd:38 txqueuelen 1000 (Ethernet)
TX packets 83 bytes 15808 (15.4 KiB)
ip route show
default via 192.168.1.1 dev end0 metric 101
default via 192.168.225.1 dev enu1 src 192.168.225.28 metric 102
172.30.32.0/23 dev hassio scope link src 172.30.32.1
172.30.232.0/23 dev docker0 scope link src 172.30.232.1
192.168.1.0/24 dev end0 scope link src 192.168.1.133 metric 101
192.168.192.0/24 dev ztwdjmset2 scope link src 192.168.192.103
192.168.225.0/24 dev enu1 scope link src 192.168.225.28 metric 102
log
Enregistreur: aiodhcpwatcher
Source: runner.py:154
S'est produit pour la première fois: 18:14:02 (33 occurrences)
Dernier enregistrement: 20:17:41
Error while processing dhcp packet: [Errno 100] Network is down
Enregistreur: homeassistant.components.homeassistant_alerts.coordinator
Source: helpers/update_coordinator.py:393
intégration: Home Assistant Alerts (documentation, problèmes)
S'est produit pour la première fois: 19:35:07 (1 occurrence)
Dernier enregistrement: 19:35:07
Error requesting homeassistant_alerts data: Cannot connect to host alerts.home-assistant.io:443 ssl:default [Timeout while contacting DNS servers]
Enregistreur: zeroconf
Source: /usr/local/lib/python3.13/site-packages/zeroconf/_logger.py:88
S'est produit pour la première fois: 18:14:11 (2 occurrences)
Dernier enregistrement: 18:14:11
Error with socket 15 (('192.168.225.28', 5353))): [Errno 101] Network unreachable
Error with socket 16 (('fe80::839a:8b38:4658:6436', 5353, 0, 4))): [Errno 101] Network unreachable
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 1268, in sendto
self._sock.sendto(data, addr)
OSError: [Errno 101] Network unreachable
I don’t know what to do to configure it correctly.
If anyone can help me,
