Hi everybody,
I’m trying to configure ESPHome to control my single RGB LED. I’m using a Wemos D1 Mini which has a 16-bit-expander board PCF8575 attached as I need more GPIOs as the Wemos offers.
My RGB LED is attached to pin 10, 11 and 12 of the PCF8575 and configured as following:
i2c:
sda: D2
scl: D1
pcf8574:
- id: 'pcf8575_hub'
address: 0x20
pcf8575: true
switch:
- platform: gpio
pin:
pcf8574: pcf8575_hub
# Use pin number 10
number: 10
# One of INPUT or OUTPUT
mode:
output: true
inverted: true
- platform: gpio
pin:
# Use pin number 11
number: 11
mode:
output: true
inverted: true
- platform: gpio
pin:
# Use pin number 12
number: 12
mode:
output: true
inverted: true
So far so good, I have now 3 switches to control the 3 colors the RGB LED offers.
But it would be more comfortable use the “light” component like this:
light:
- platform: rgb
red: output_red
green: output_green
blue: output_blue
output:
- platform: esp8266_pwm
pin: D5
pin: D6
pin: D7
Unfortunately the esp8266_pwm component does not accept the PCF8575 pins:
output.esp8266_pwm: [source /config/esphome/myproject.yaml:181]
pin:
[pcf8574] is an invalid option for [pin].
Anyone an idea how I could use the “light” component with the PCF8575 expander?
