Configure aeotec temp sensor on hassio
HI,
would you be able to help me?
how to configure aeotec temp sensor on hassio.
-sensor.aeotec_zw100_multisensor_6_temperature
to trigger “on” ,at a certain temperature 8 ℃ , z wave wall outlet :
-switch.telldus_tzwp100_plugin_switch_switch_4
and at a certain temperature14 ℃ trigger off,
-switch.telldus_tzwp100_plugin_switch_switch_4.
The switch.telldus_tzwp100_plugin_switch_switch_4 ,is connected to heat fan.
Any suggestions?
Christian
If what you are after is the switch to turn on when the temp is at or below 8C and off when the temp is at or above 14C, you need two automations. One to turn off, one to turn on.
- alias: Heater Turn On
  initial_state: true
  - platform: state
    entity_id: sensor.aeotec_zw100_multisensor_6_temperature
    below: '9'
  - service: switch.turn_on
    entity_id: switch.telldus_tzwp100_plugin_switch_switch_4
- alias: Heater Turn Off
  initial_state: true
  - platform: state
    above: '13'
  - service: switch.turn_off
Thanks,
I will try.
