I have configured lights in lovelace dashboard using custom button-card. I can change the light or light group color by accessing color-wheel with more-info command.
Is there is any way to assign one button-card with single color and clicking on button shall change the color of the light/light-group.
In action->call-service/service is not changing the color of the light.
Any help is highly appreciated. thanks
The first one controls a group (defined in configuration.yaml) so that I can control them all in unison. The others give me the ability to control them individually.
There are additional options described in the github pages for these custom cards. At first I also declared a default brightness of 255 (100%) but since I added the slider, I removed that to avoid blasting the light at max whenever I change color.
Since me device names are long, they don’t fit on the same row as the slider and toggle therefore I use a section divider which also supports a label which is where I put the full device name, and then used a generic name for the device (ie Table Lamp).
EDIT: The style is only to make the card title smaller as it looks way too large, especially on a phone.
Edit2: added card_mod: before style which is now the correct way of using style.
@careingemt Create a card (any card), go to YAML editing mode and replace all of the code with the second code snippet I shared in a previous post. Then edit the entities and labels to match your RGB light. The github page for the cards I used gives all the details on how to configure everything but I am guessing what I already did might just work for you as is. Don’t forget to install the custom cards in HACS before doing this otherwise it won’t work.
Also, you can get rid of the card_mod: and style section as that only formats the card title to a smaller font.
No, you have to edit your dashboard but first you must install the custom cards using HACS.
Then install the two cards. Their github pages give all the install and configuration options you need but if you like what I did, all you really need to do is add them using HACS. Search for them under “Frontend”.
Once that is done, you can freely use them in your dashboards… so time to edit one and add a card:
I picked Alarm Panel Card, but it really doesn’t matter. There is a way to just start with a blank card, but I find this to be faster/easier. Click “Show Code Editor”:
Hit save and it should work assuming the cards are installed and the entities are typed in correctly… and you copied in all of the code I shared above. I am sharing the same code below with a few changes in hopes it makes it easier for you (so it won’t match the screenshots):
Just in case… the “light.replace_this_with_light_name” must be the entity name of your RGB light so its name will be something like light.bedroom_light - if you get this wrong, it won’t know what device you are trying to control. The same device (entity) appears in several spots as the card above is actually multiple cards put together.
First off, thanks so much for sharing your code! I’ve started using it on my dashboard, and it’s almost perfect.
I was trying to search the docs of the related cards, and couldn’t find what I was looking for - maybe you would.
Is there a way to add a toggle to the top of the lights, to essentially hide the panel? I included a screenshot with a sample toggle (the crappily drawn arrow lol).
