Dear all,
I migrated to 2021.8.x and, as suggested, in the changelog I removed fritzbox_netmonitor entry from my Configuration.yaml.
But after that, I can’t access anymore to the data provides by this integration. For example, a template that contains this string doesn’t work anymore
How can I gain access to this informations?
I added the fritz integration for my router and mesh satellites. Maybe I missed some other configuration?
Many thanks in advance.
Thank you @starob.
Just another info.
What is the unit of measure of sensor.fritz_box_7530_max_kbit_s_received ?
kibibit or kilobit ?
Because max_byte_rate_down was expressed in bytes/s and I need to to the necessary adjustments.
Is there a link where to find a mapping for old sensor name → new sensor name?
I’m rewriting a package that monitor fritz and I can’t find the equivalent for
