Hi, I have two energy consumption meters: from EFERGY and from PRISM (Prism Cartender an Italian Wallbox producer, which works very well).
For both I have Voltage Ampere, Power.
How to make them work inside the new Energy system?
Convert power to energy using the integration integration. Be sure to use the left method.
Hi what do you mean with left method?
The Efergy I already have this
- platform: integration
source: sensor.efergy_802171
unit_prefix: k
round: 2
but the sensor is not between the one I can use
Ok now I see left method. Like this??
##### da potenza instantanea a energia
unit_prefix: k
round: 2
method: left
I used this method but the two entity do not appear in the dropdown menu
Ok so perhaps the platform INTEGRATION has no possibility to have a state_class=measurement ???
Ok I tried other MQTT sensor
- platform: mqtt
name: "Prism energia totale"
state_topic: "prism/1/wh_total"
unit_of_measurement: 'Wh'
state_class: "measurement"
but also this sensor.prism_energia_totale does not appear in list dropdown
Any hint?
