Configure Home Assistant Documentation unclear
Hey guys,
This documentation is really unclear and missing steps, kinda like step 1, step two, step 10: and now you’re done, easy as that lol
Doesn’t tell you to, click browse file system in the left-hand top corner, then choose configuration.yaml, then enter the code.
Time for the first practice with the configurator. Add the following to configuration.yaml file to add a link to the Configurator in the sidebar:
panel_iframe:
configurator:
title: Configurator
icon: mdi:wrench
url: http://hassio.local:3218
Now restart Home Assistant for the changes to the configuration to take effect. You can do this by going to the config panel (Configuration in the sidebar) -> General -> Restart Home Assistant.
Also, I have no idea where to enter the code, I’ve just put it here;
# Enables configuration UI
config:
panel_iframe:
  configurator:
    title: Configurator
    icon: mdi:wrench
http:
  # Secrets are defined in the file secrets.yaml
It works, so I guess it’s fine to just put it anywhere?
yep, put it anywhere.
treat the configuration.yaml file as a container. For example if you have a bag and you put a bunch of fruit in it, does it matter which fruit goes in first? No. Just start chucking crap in it. All that matters is the format. Spacing/indents matter, DO NOT USE TABS ONLY SPACES.
I would not put my bananas under my watermelon, but I guess that’s a different story :smiley:
Thanks guys,
It may have been something hidden character, but now I’m having other issues with the webgui refusing to show.
Ill put it in a new post though.
Thanks again
