I’d like to configure a button to play a particular internet radio station (Radio Paradise, an Internet-only station) on a device, but I can’t find a simple example of configuring media_player.play_media to take a random stream url (e.g., https://stream.radioparadise.com/aac-128). Is that possible? Can someone show me an example?
From a dashboard button:
hold_action:
action: call-service
service: media_player.play_media
service_data:
entity_id: media_player.bedroom_speaker
media_content_id: 'http://ice-the.musicradio.com/HeartBedfordshire'
media_content_type: audio/mp4
Thanks for that @TazUk, that put me on the right track. I eventually got this working, like so (using Bose Soundtouch integration) in a script, which I’ve assigned to a button. I could probably simplify this:
play_radioparadise_everywhere:
alias: "Play Radioparadise everywhere"
sequence:
- service: media_player.turn_on
entity_id: media_player.soundtouch_living_room
entity_id: media_player.soundtouch_kitchen
- service: soundtouch.play_everywhere
master: media_player.soundtouch_living_room
- service: media_player.play_media
media_content_id: http://stream.radioparadise.com/aac-128
media_content_type: MUSIC
So, what am I doing wrong here??
show_name: true
show_icon: true
type: button
tap_action:
action: toggle
hold_action:
media_content_id: Listening to: KEWR Tower #1 | Newark, New Jersey, United States | LiveATC.net
enqueue: play
entity_id: media_player.scott_s_office
entity: media_player.scott_s_office
show_state: true
Without seeing the formatting…
Does the service call work from Developer Tools with the parameters you are using?
Not sure of this. I merely got some sample code from HA but can not get it to work.
Well then I’d suggest trying the calls in Developer Tools…
Sorry…may be beyond my understanding. Can you provide a bit of a hint. Would this be a Call Service? If so, how???
Test your service call in the services section.
This will tell you whether what you are trying to do will work.
If your service call works in developer tools, then it is your dashboard code that needs adjusting.
To get help with the dashboard code you will need to format it properly when posting it - see this.
Interesting…Alexa is telling me that I’m trying to do TTS. I must be totally lost on this one. Can’t believe there’s not an existing Integration to play internet streaming audio.
Thanks anyway.
s
Progress…I dropped it into Developer Tools and when I call the service I get a GREEN CHECKMARK but I’m still not hearing anything.
So the service call is valid.
Loading the stream url you are using does not autoplay in my browser, whereas http://ice-the.musicradio.com/HeartBedfordshire does.
See if that works.
getting a bit frustrated here. Tried plugging it all into the mini-media player and although it appears valid, there is NO SOUND
type: custom:mini-media-player
media_content_id: http://ice-the.musicradio.com/HeartBedfordshire
enqueue: play
device_id: 1b6c4b692ea4c530d934705c6dd24270
volume_stateless: true
info: scroll
source: icon
sound_mode: full
Any thoughts??? ps. sorry for the BOLD letters. I’m not screaming ![]()
- If you don’t get sound using the Developer Tools > Services interface, you won’t get sound calling the service from anywhere else.
- Please don’t post code without formatting.
My call works with a Nest Home Hub Max in HA v2022.7.7 - we don’t have any Amazon devices so I don’t know whether there are any differences in how they behave.
In fact, a quick search of the community turns up this post by sparkydave that implies that Amazon devices are (or were) known to be difficult.
I suspect that if you dig around the community you may find further info on that - failing that I’d suggest starting a new thread with the specific end to end details of what you want to achieve (and formatted code please).
sorry about the unformatted code. Could you please explain and I’ll be glad to comply.
With regards to my inquiry, I will try on a SONOS and see if there’s any luck there. thanks for your reply.
OK…so no luck trying to go to SONOS either. Ironically, I do hear error messages from SONOS when I change the code parameters. Has anyone heard of a custom integration to do this using Amazon Alexa?
any help here? I’m a newbie but learning fast.
media_content_id: http://d.liveatc.net/kewr_twr
media_content_type: playlist
enqueue: replace
entity_id: media_player.nest_office
Pls remember - you can’t play media on Alexa devices like Echo. Use other sound device like Google Nest or other compatible loudspeaker device. I noticed that after starting this stream, it starts working after a few dozen seconds.
In case anyone is still monitoring this thread …
I just developed a new SoundTouchPlus custom component if you’re interested. It can easily be installed via HACS as well. More information can be found in this forum post.
It can play HTTPS media streams. Example:
media_content_type: music
media_content_id: >-
entity_id: media_player.soundtouch_10
hello ,
i have the same question ,
is this solved or is there a walkaround ??
my yaml code that wont hear anything is :
entity_id: media_player.kantoor
