I’m a new in Home Assistant,
My goal is to control over the blinds in the living room.
The device i use is Sonoff 4ch Pro with Stefanbode’s firmware.
I’m able two separate blinds from the device’s UI, an i’m trying to implement the same in the Home Assistant.
So i defined two covers, as follow:
cover:
platform: mqtt
unique_id: “saloon_1”
availability_topic: “tele/sonoffDEV1/LWT”
payload_available: “Online”
payload_not_available: “Offline”
position_topic: stat/sonoff/SHUTTER1
position_open: 100
position_closed: 0
set_position_topic: “cmnd/sonoff/shutterposition1”
command_topic: “cmnd/sonoff/backlog”
payload_open: “SHUTTEROPEN”
payload_close: “SHUTTERCLOSE”
payload_stop: “SHUTTERSTOP”
retain: false
optimistic: false
qos: 1 -
platform: mqtt
unique_id: “saloon_2”
availability_topic: “tele/sonoff/LWT”
position_topic: stat/sonoff/SHUTTER2
position_open: 100
position_closed: 0
set_position_topic: “cmnd/sonoff/shutterposition2”
retain: false
optimistic: false
qos: 1
I see in the UI the two blinds controls with Up, Down and Stop buttons, but both control same cover.
What am i doing wrong ?
