I am implementing a custom device_tracker integration, which should be able to track multiple devices by querying an HTTP(S) endpoint. Each device has its own set of credentials (id and private_key), which the user should be able to enter through the initial config flow triggered via the UI.
Going through the documentation I couldn’t really find if there is a way to enter multiple sets of credentials through a config flow. What I would like to have is some kind of form where the user can click a + button and an additional set of fields (id and private_key) would appear. Is this functionality available in home assistant?
Thanks for any hints and help!
