Configure SMA Solar custom sensor setup
Hi y’all,
i’m a bit lost here and i hope someone could enlighten me…
I do have an SMA Solar Inverter and have enabled the SMA integration of HA according to this: homeassistant//integrations/sma/
Everything worls as expected.
Now i want to add a custom sensor as described in the manual above, but i don’t know, where to put the custom: thing.
If i put it like this
  - platform: sma
    host: IP_ADDRESS_OF_DEVICE
    ssl: true
    verify_ssl: false
    password: YOUR_SMA_PASSWORD
    sensors:
      - current_consumption
      - total_consumption
      - pv_power
      - total_yield
    custom:
      yesterday_consumption:
        key: "6400_00543A01"
        unit: kWh
        factor: 1000
it gives me an error upon config-check like this:
Invalid config for [sensor.sma]: expected dictionary for dictionary value @ data['custom']. Got [OrderedDict([('total_consumption', OrderedDict([('key', '6400_00462500'), ('unit', 'kWh'), ('factor', 1000)]))])]. (See ?, line ?).
am i overlooking something here or am i just to stup… to read the manual?
Ok, my bad.
Just was to stupid to see the double quotes at the key value.
Changed it to simple quotes and it’s up and running.
:man_facepalming:
