cnoork
(Chris)
December 29, 2019, 9:00pm
1
I have already for a while Sonoff devices which I automated with scripts. Now I want them to integrate with HA but till now I could not get it work.
Here the settings from my Sonoff:
Here my HA settings (MQTT done with integrations and is working perfectly for zigbee2mqtt):
And here you can see that the example device is working through node red:
Who can give me a suggestion where I could look or what I did overlook
nickrout
(Nick Rout)
December 29, 2019, 9:09pm
2
Use mosquitto_sub to check what is being received on the broker.
cnoork
(Chris)
December 29, 2019, 9:21pm
3
Hi nickrout, thnx for thinking with me, the output gives the same result as the Node Red:
nickrout
(Nick Rout)
December 29, 2019, 9:33pm
4
Do you see it in developer tools|state page?
cnoork
(Chris)
December 29, 2019, 9:36pm
5
Hi nickrout,
Yes I see the device there:
And it is also switching from 0 to 1 when I press the button…
cnoork
(Chris)
December 29, 2019, 9:43pm
6
Found now also that I can use “switch.sonoff01” in lovelace. Thank you very much. Is it also possible to get an entry in the Device list?
nickrout
(Nick Rout)
December 29, 2019, 9:49pm
7
I am not sure about that. I think that might require mqrr discovery. Does esp easy support ha discovery?
cnoork
(Chris)
December 29, 2019, 9:53pm
8
I have read something about it but then you need to compile the code yourself, I will check or I will look for another firmware which is enabled for ha discovery. If that is the trick I will google on that. Thank you for you very fast responses…
nickrout
(Nick Rout)
December 29, 2019, 9:55pm
9
Tasmota has ha discovery built in. Esphome.io is also very nice.
cnoork
(Chris)
December 29, 2019, 10:47pm
10
Hi nickrout,
I have solved it with Tasmota, thnx. Here are the steps I did for documentation to others:
Downloaded the latest version from Tasmota on https://tasmota.github.io/docs/#/Home
I have set the wifi and Home Assistant settings (SetOptionXX) through serial console termite (https://www.compuphase.com/software_termite.htm ):
ssid1 “the wifi ssid”
Password1 “password from ssid”
SetOption19 1
SetOption59 1
FriendlyName sonoff01
Topic sonoff01
After that I have filled in the following through the web interface:
Configuration Module --> selected the Sonoff model
MQTT --> my Host, User and Password
Now I have the Sonoff as I would like to have, Sonoff integrated in HA.
