Configure SP816 NEXA PIR in home assistant
HI, how to install and configure SP816 NEXA PIR in home assistant hassio.
configuration.yaml, and automation.yaml to turn on a lamp.
thanks
Do you have a Z-wave network established? This appears to be a z-wave sensor.
Add devices
Once you have it added we can discuss automating. Is your lamp connected to home assistant?
I’ve done that
has put in the battery in the Nexan SP816 pier and has taken out the aeotec stick out of raspberry, then pressed the button aeotec,
nexan blinked red, late was red 4 seconds.
then I connected aeotec in rasperry.
but it didn’t get anything in the HA.
tried with, Z-Wave Network Management pressed ADD NODE button becomes green, then I checked if the node exists but there is not.
I hope I have explained everything right.
