Configure switch to turn on/off based on Temperature between time
Hello, I am fairly new to this and have a question that the community experts might be able to help with. I have configured the below in the automations.yaml file, however I would like for the switch to only be on between a certain time, say on at '07:00:00 and off at ‘19:00:00’ and for said temperature to turn the ac off/on between that time. I know that this would more than likely be a condition but I am having a hard time with formatting that template correctly. Any help would greatly be appreciated
- id: ChickenCoopAC_OffBasedOnTemperature
  alias: Turn off Chickencoop AC at 75 Degrees
    platform: numeric_state
    entity_id: sensor.chicken_coop_temperature
    below: 75
    service: switch.turn_off
    entity_id: switch.chickencoop_ac
- id: ChickenCoopRunAC_OnBasedOnTemperature
  alias: Turn on Chickencoop Run AC at 80 Degrees
  - platform: numeric_state
    above: '80'
  - service: switch.turn_on
    entity_id: switch.chickencoop_run_ac
- alias: Set chicken coop AC
      above: 80
      below: 75
    - platform: time
      at:
        - '07:00:00'
        - '19:00:00'
  condition:
    condition: time
    after: '07:00:00'
    before: '19:01:00'
    service: >
      {% if states('sensor.chicken_coop_temperature')|int > 79
        and now().hour in [7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18] %}
          switch.turn _on
      {% else %} switch.turn_off {% endif %}
If you’re on any version below 115 change service to service_template
Hello, thank you for your quick reply and for the automation. The community is awesome!
The automation turned off the switch however it did not turn on the switch “switch.chickencoop_ac”. The “sensor.chicken_coop_temperature” is now above 80 degrees and with in the condition of time but has not turned on the switch “switch.chickencoop_ac”. I am currently running version 0.115.2
Any suggestion would greatly be appreciated
Can you double check the template in the template editor?
I get the following in the template editor
switch.turn _on
This template listens for the following state changed events:
  • Entity : sensor.chicken_coop_temperature
And did the automation fire on numeric_state in your logbook?
Oh, I’ve spotted it, I accidentally put a space in switch.turn_on in the template, remove the space and it will work.
That worked! This has been solved
Really appreciate the community!!
I had an interesting thought. Do you think it is possible to writhe this where instead of between time it is between sunrise and sunset?
      above: 80
      below: 75
    - platform: state
      entity_id: sun.sun
    service: >
        and is_state('sun.sun', 'above_horizon') %}
          switch.turn_on
It’s working! Thank you very much
Im trying to figure out how to create an automation that will turn my sons heater on (input_boolean) based on the temperature being less than or equal too 67 degrees Fahrenheit using ecobee temp sensor in his room. Also have it turn off at 70 degrees Fahrenheit and only if presence is detected and only between the hours of 8pm - 4am and only in the winter months based on outside temp which I have smart weather station for that entity as well. Im sure with all you brilliant minds in here this is probably easy for you all but for me im lost. Thank you in advanced
