When setting up a new Utility_meter through the helpers, you can specify a tarif.
The description says:
“A list of supported tariffs, leave empty if only a single tariff is needed”.
BUT:
It is not possible to set up the tariffs option later - after the utility meter has been created.
The “Utility Meter Option” is only providing a setup dialog for the source sensor, but not for any other settings that you might need to adapt.
The only way to “solve” this:
- Delete the existing Utility Meter and create it again, with using the same Name (in this case, it will get the same entity_id)
I would like to see a more extended options to change the parameters of the utility meter later - whenever it might be required.
