I finally upgraded to the newer version of HA and renamed al my RFXcom devices. One issue remains; how do I now get rid of the flash-icons and change them to a toggle switch? The other entities already have this (Hue lights). ‘Lampjes bank’ are switch on/off by a Kaku wall socket.
Any clue? I didn’t found a solution yet.
Can you share the yaml you used to define that switch?
@Marcel030nl did you ever solved the issue in converting the flashing icons to a toggle switch?
I everyone, I finally solved the issue.
I have started to migrate my old RFXcom integation to the new RFXcom integration supported with GUI, but as all of my switches are added … as switches … they get the above metioned flash-icone and not the expected/wanted toggle.
Found this documentation Light Switch - Home Assistant
light:
- platform: switch
name: SONOS Kontor sw
entity_id: switch.ac_38bf39a_1
Thank you! So happy that you’ve shared this for future reference.
I have to be honest; in some cases I replaced the RFXCOM switch with a HUE light
