Configure "unknown" Z-Wave device (Popp Keypad)
I just got the quite new Popp Keypad, intended to be used together with my Danalock V3.
It seems to be securely added via ozwcp, however, I cannot set associations there or in Home Assistant’s control panel. Aren’t association groups announced by the device automatically?
I also tried the following with no luck.
zwave.change_association { “association”: “add”, “node_id”: 30, “target_node_id”: 2, “group”: 2 }
I would think it should be possible to utilize basic functions of this keypad without it being supported explicitly by Home Assistant (openzwave), however, it doesn’t seem so. Have I done anything wrong, or do I need to try to add its description to openzwave?
I’m also interested (haven’t bought it yet).
Fixed in https://github.com/OpenZWave/open-zwave/commit/2edc26684d91d808e2bebf172e0372a34258ef1c
Hi, Did you get it to work with home assistant?
Yes, now without any custom open-zwave :slight_smile: (I haven’t tried including it, but I think it should work)
