I’m new to Hassio but are use to using Openhab 1.8 on a CentOS server.
I plan to migrate from Openhab to Hassio on a Raspberry Pi 3 specially purchased for controlling all my Z-Wave devices. Installation of Hassio is fairly straight forward and no problem. When trying to connect with my z-wave I fail to do so. The Z-Wave stick used is a “Aeotec Z-Stick Series 2” which works fine on the openhab installation, but I can’t find the stick on the Raspberry Pi 3.
What did I miss? Can anyone help out please?
I added zwave:
To the config with and without the path to the device.
Somehow I suspect the problem is that there is no device mapping created in /dev , but I might be wrong:
See the listing of /dev
core-ssh:/dev# ls -la /dev
total 500
drwxr-xr-x 5 root root 360 Feb 18 12:19 .
drwxr-xr-x 52 root root 4096 Feb 18 12:19 ..
lrwxrwxrwx 1 root root 13 Feb 18 12:19 fd -> /proc/self/fd
crw-rw-rw- 1 root root 1, 7 Feb 18 12:19 full
-rwxr-xr-x 1 root root 506092 Sep 17 21:17 init
-rw-r--r-- 1 root root 36 Feb 18 12:19 kmsg
drwxrwxrwt 2 root root 40 Feb 18 12:19 mqueue
crw-rw-rw- 1 root root 1, 3 Feb 18 12:19 null
lrwxrwxrwx 1 root root 8 Feb 18 12:19 ptmx -> pts/ptmx
drwxr-xr-x 2 root root 0 Feb 18 12:19 pts
crw-rw-rw- 1 root root 1, 8 Feb 18 12:19 random
drwxrwxrwt 2 root root 40 Feb 18 12:19 shm
lrwxrwxrwx 1 root root 15 Feb 18 12:19 stderr -> /proc/self/fd/2
lrwxrwxrwx 1 root root 15 Feb 18 12:19 stdin -> /proc/self/fd/0
lrwxrwxrwx 1 root root 15 Feb 18 12:19 stdout -> /proc/self/fd/1
crw-rw-rw- 1 root root 5, 0 Feb 18 12:19 tty
crw-rw-rw- 1 root root 1, 9 Feb 18 12:19 urandom
crw-rw-rw- 1 root root 1, 5 Feb 18 12:19 zero
While the USB stick is somewhat recognized see part of the output of dmesg
[93159.555051] usb 1-1.5: new full-speed USB device number 11 using dwc_otg
[93159.661624] usb 1-1.5: New USB device found, idVendor=10c4, idProduct=ea60
[93159.661644] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[93159.661657] usb 1-1.5: Product: CP2102 USB to UART Bridge Controller
[93159.661670] usb 1-1.5: Manufacturer: Silicon Labs
[93159.661682] usb 1-1.5: SerialNumber: 0001
[93159.675853] usb 1-1.5: cp210x converter now attached to ttyUSB0
For hassio, run hassio host hardware while you’re ssh’ed into the ssh addon and you should see the list of serial devices visible by your hassio machine. Remember to restart
