I updated HassIO to the latest version. When I configure an integration it won’t show in the dasboard. The dashboard stays blank. What can I do to solve this problem. Everything worked fine till version 0.93.2
At some point you have taken control of Lovelace. It will no longer automatically place cards for you.
This is a good thing. You now have complete control of what is visible.
Click the three dots icon upper right and select “Configure UI”.
Click the (+) icon lower right and add whatever type of card (right hand column) you want.
e.g. add an entities card. Select the entities you want in the card using the drop down lists. Fill in the other card details and click save.
Try a glances card.
You also can add new views along the top of the page.
Click the X upper right of the page to exit UI edit mode.
