Hi all and thanks for sharing Stiebel tips and information. I’m trying to connect my Stiebel Eltron WPF 10 heat pump can bus with Wemos D1 mini pro and MCP2515 can board. Basically configuration is based on the instructions given here: CAN bus — ESPHome
With the below pasted .yaml I do get some data, like heating and boiler temperatures and after a while also one of the COPs is shown. But most of the measurements stays in N/A state. Any ideas what could be wrong in my configuration?
I also noted that when my ESP is connected to the can bus of the pump, the pump’s menus comes quite slow. Sometimes it even shown an empty submenu / no measurements at all. But going one step back in the menu and retrying usually helps and the measurements are again correctly shown. It looks like my ESP is somehow messing out the can bus…?
PS. like you see, my code is almost like copy-paste from this site posts
esphome:
platform: ESP8266
board: d1_mini_pro
# Enable logging
logger:
# Enable Home Assistant API
api:
# password: "<password>"
services:
- service: pull_canmsg
variables:
idx: int
addr: int
val: int
then:
- lambda: |-
int getA = static_cast<int>(addr); //Adresse in Byte 0 u. 1 schreiben
id(sh_state)[0]=getA>>8;
id(sh_state)[1]=getA-((getA>>8)<<8);
getA = static_cast<int>(idx); //Elster-Index übernehmen // Ota käyttöön Elster-indeksi
//Wenn Elster-Index <= 0xff => an Byte-Stelle 2 schreiben //Jos Elster-indeksi <= 0xff => kirjoita tavupaikkaan 2
if( (getA>>8) == 0x00) {
id(sh_state)[2]=getA-((getA>>8)<<8);
getA = static_cast<int>(val); //Datenwert übernehmen und an Stelle 3 u. 4 schreiben, 5 u. 6 ist 0x00 // Ota tietoarvo ja kirjoita paikkoihin 3 ja 4, 5 ja 6 on 0x00
id(sh_state)[3]=getA>>8;
id(sh_state)[4]=getA-((getA>>8)<<8);
id(sh_state)[5]=0x00;
id(sh_state)[6]=0x00;
else {
//Wenn Elster-Index > 0xff kommt 0xfa an Stelle 2, der Index steht dann an Stelle 3 u. 4 //Jos Elster-indeksi > 0xff, 0xfa tulee paikalleen 2, indeksi on silloin paikoissa 3 ja 4
id(sh_state)[2]=0xfa;
getA = static_cast<int>(val); //der Datenwert steht dann an Stelle 5 u. 6 //tietoarvo on silloin paikoissa 5 ja 6
id(sh_state)[5]=getA>>8;
id(sh_state)[6]=getA-((getA>>8)<<8);
#Temporaly removed when debuging wifi problem..
# ota:
# password: !secret ota_password
# safe_mode: true
# reboot_timeout: 10min
# num_attempts: 5
wifi:
fast_connect: true
ssid: !secret wifi_ssid
# ap:
# ssid: heatpump
#captive_portal:
web_server:
port: 80
auth:
username: !secret web_uname
password: !secret web_pw
#Joku bugi, ilman debugia wifiin yhditäminen failaa
#Bug? WiFi connection fails without debug..
debug:
globals:
#Array zum Senden von Can-Bus Befehl aus Home-Assistant
#Matriisi Can-Bus-komennon lähettämiseen Home Assistantista
- id: sh_state
type: int[7]
initial_value: '{0x00,0x00,0x00,0x00,0x00,0x00,0x00}'
restore_value: no
#Array zum Senden von Can-Bus Befehl aus Programmcode
#Matriisi Can-Bus-komennon lähettämiseen ohjelmakoodista
- id: send_state
type: int[7]
restore_value: no
- id: el_aufnahmeleistung_ww_tag_wh_float
type: float
restore_value: no
- id: el_aufnahmeleistung_ww_tag_wh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_ww_tag_kwh
type: float
restore_value: no
- id: el_aufnahmeleistung_ww_tag_kwh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_heiz_tag_wh_float
type: float
restore_value: no
- id: el_aufnahmeleistung_heiz_tag_wh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_heiz_tag_kwh
type: float
restore_value: no
- id: el_aufnahmeleistung_heiz_tag_kwh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_ww_total_kWh_float
type: float
restore_value: no
- id: el_aufnahmeleistung_ww_total_kWh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_ww_total_mWh
type: float
restore_value: no
- id: el_aufnahmeleistung_ww_total_mWh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_heiz_total_kWh_float
type: float
restore_value: no
- id: el_aufnahmeleistung_heiz_total_kWh_flag
type: bool
restore_value: no
- id: el_aufnahmeleistung_heiz_total_mWh
type: float
restore_value: no
- id: volumenstrom_float
type: float
restore_value: no
- id: el_aufnahmeleistung_heiz_total_mWh_flag
type: bool
restore_value: no
- id: VD_starts_h
type: int
initial_value: '0'
restore_value: no
- id: VD_starts_t
initial_value: '0'
type: float
restore_value: no
- id: waermemertrag_ww_tag_wh_float
type: float
restore_value: no
- id: waermemertrag_ww_tag_wh_flag
type: bool
restore_value: no
- id: waermemertrag_ww_tag_kwh
type: float
restore_value: no
- id: waermemertrag_ww_tag_kwh_flag
type: bool
- id: waermemertrag_electr_ww_tag_wh_float
type: float
restore_value: no
- id: waermemertrag_electr_ww_tag_wh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_ww_tag_kwh
type: float
restore_value: no
- id: waermemertrag_electr_ww_tag_kwh_flag
type: bool
restore_value: no
- id: waermemertrag_heiz_tag_wh_float
type: float
restore_value: no
- id: waermemertrag_heiz_tag_wh_flag
type: bool
restore_value: no
- id: waermemertrag_heiz_tag_kwh
type: float
restore_value: no
- id: waermemertrag_heiz_tag_kwh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_heiz_tag_wh_float
type: float
restore_value: no
- id: waermemertrag_electr_heiz_tag_wh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_heiz_tag_kwh
type: float
restore_value: no
- id: waermemertrag_electr_heiz_tag_kwh_flag
type: bool
restore_value: no
- id: waermemertrag_ww_total_kWh_float
type: float
restore_value: no
- id: waermemertrag_ww_total_kWh_flag
type: bool
restore_value: no
- id: waermemertrag_ww_total_mWh
type: float
restore_value: no
- id: waermemertrag_ww_total_mWh_flag
type: bool
restore_value: no
- id: waermemertrag_heiz_total_kWh_float
type: float
restore_value: no
- id: waermemertrag_heiz_total_kWh_flag
type: bool
restore_value: no
- id: waermemertrag_heiz_total_mWh
type: float
restore_value: no
- id: waermemertrag_heiz_total_mWh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_heiz_total_kWh_float
type: float
restore_value: no
- id: waermemertrag_electr_heiz_total_kWh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_heiz_total_mWh
type: float
restore_value: no
- id: waermemertrag_electr_heiz_total_mWh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_ww_total_kWh_float
type: float
restore_value: no
- id: waermemertrag_electr_ww_total_kWh_flag
type: bool
restore_value: no
- id: waermemertrag_electr_ww_total_mWh
type: float
restore_value: no
- id: waermemertrag_electr_ww_total_mWh_flag
type: bool
restore_value: no
#Abfrage des Sensorstatus durch Ausführen des Lambda-Befehls. send_state wird auf das request-Paket gesetzt. Anschließend wird Update_sensor aktiviert, der den Befehl via CAN absetzt und wieder deaktiviert
#Anturin tilan kyseleminen suorittamalla Lambda-komento. send_state on asetettu pyyntöpakettiin. Sitten Update_sensor aktivoituu, joka lähettää komennon CAN:n kautta ja deaktivoi sen uudelleen
#name: "Außentemperatur"
unit_of_measurement: "°C"
icon: "mdi:thermometer-lines"
device_class: "temperature"
state_class: "measurement"
accuracy_decimals: 1
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x00;id(send_state)[4]=0x0c;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
id(update_sensor).publish_state(true);
id(update_sensor).publish_state(false);
return {};
update_interval: 10min
#name: "Quellentemperatur"
name: "Lähteen lämpötila"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x01;id(send_state)[4]=0xd4;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
#name: "Warmwassertemperatur"
name: "Lämpimän veden lämpötila"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0x0e;id(send_state)[3]=0x01;id(send_state)[4]=0x00;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
#In Planung
# - platform: template
# name: "WW_Programmstart"
# id: ww_start
# icon: "mdi:timer-play"
# state_class: "measurement"
# accuracy_decimals: 0
#In Planung
# name: "WW_Programmende"
# id: ww_ende
# icon: "mdi:timer-stop"
#Berechnung COP erfolgt über Sensoren für Stromverbrauch und Wärmeproduktion - kein aktiver Update-Befehl
##COP:n laskenta tapahtuu sähkönkulutuksen ja lämmöntuotannon antureiden kautta - ei aktiivista päivityskomentoa
#name: "Verdichterstarts"
name: "Kompressori käynnistyy"
unit_of_measurement: "a.u."
icon: "mdi:chart-bell-curve-cumulative"
device_class: "power_factor"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x07;id(send_state)[4]=0x1c;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x07;id(send_state)[4]=0x1d;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
if (id(VD_starts_t>0) and id(VD_starts_h>0)){
float VD_starts_float = id(VD_starts_h)+id(VD_starts_t);
return VD_starts_float;
else {return {};}
update_interval: 5h
#name: "COP-Wert Heizung"
name: "COP-arvo lämmitys"
accuracy_decimals: 2
lambda: |-
id(total_electric_energy_heating).update();
id(total_heating_energy).update();
id(total_electric_heating_energy).update();
float heat_cop_float = (id(waermemertrag_heiz_total_mWh)+id(waermemertrag_electr_heiz_total_mWh))/id(el_aufnahmeleistung_heiz_total_mWh);
return heat_cop_float;
force_update: true
#name: "COP-Wert Warmwasser"
name: "COP-arvo lämmin vesi"
lambda: |-
id(total_heating_energy_water).update();
id(total_electric_energy_water).update();
float ww_cop_float = (id(waermemertrag_ww_total_mWh)+id(waermemertrag_electr_ww_total_mWh))/id(el_aufnahmeleistung_ww_total_mWh);
return ww_cop_float;
force_update: true
#name: "COP-Wert Gesamt"
name: "COP-arvo yhteensä"
lambda: |-
id(cop_water).update();
id(cop_heater).update();
float total_cop_float = ((id(waermemertrag_heiz_total_mWh)+id(waermemertrag_electr_heiz_total_mWh))+(id(waermemertrag_ww_total_mWh)+id(waermemertrag_electr_ww_total_mWh)))/(id(el_aufnahmeleistung_heiz_total_mWh)+id(el_aufnahmeleistung_ww_total_mWh));
return total_cop_float;
force_update: true
update_interval: 6h
#name: "Rücklauftemperatur Heizung"
name: "Lämmityksen paluulämpötila"
icon: "mdi:waves-arrow-left"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x00;id(send_state)[4]=0x16;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
update_interval: 5min
#name: "T Heizkreis IST"
name: "T lämmityspiiri TODELLINEN"
icon: "mdi:waves-arrow-right"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x02;id(send_state)[4]=0xca;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
#name: "T Heizkreis Soll"
name: "T lämmityspiiri TAVOITE"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x01;id(send_state)[4]=0xd7;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
update_interval: 15min
#name: "Speicher Soll Temperatur"
name: "T varaajan TAVOITE"
icon: "mdi:thermometer-water"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0x03;id(send_state)[3]=0x00;id(send_state)[4]=0x00;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
#name: "Speicher IST Temperatur"
name: "T varaaja TODELLINEN"
#name: "Eco Speicher Soll Temperatur"
name: "T Eco varaajan TAVOITE"
icon: "mdi:thermometer-low"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x0a;id(send_state)[4]=0x06;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
#name: "Komfort Speicher Soll Temperatur"
name: "T Mukavuus varaaja TAVOITE"
icon: "mdi:thermometer-high"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0x13;id(send_state)[3]=0x00;id(send_state)[4]=0x00;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
#name: "Volumenstrom"
unit_of_measurement: "l/min"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x06;id(send_state)[4]=0x73;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
update_interval: 1min
#name: "Heizungsdruck"
unit_of_measurement: "bar"
icon: "mdi:gauge"
device_class: "pressure"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x06;id(send_state)[4]=0x74;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
return {};
update_interval: 7min
#name: "Puffertemperatur"
name: "Puskurivaraajan lämpötila"
#Automatische Updates durch FEK
#name: "Luftfeuchtigkeit Wohnraum"
unit_of_measurement: "%rH"
icon: "mdi:water-percent"
device_class: "humidity"
#name: "Temperatur Wohnraum"
name: "Asunnon lämpötila"
#name: "Stromverbrauch Warmwasser heute"
name: "Sähkönkulutus lämminvesi tänään"
unit_of_measurement: "kWh"
device_class: "energy"
accuracy_decimals: 3
icon: "mdi:transmission-tower"
lambda: |-
//el. Leistungsaufnahme WW Tag Wh
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x09;id(send_state)[4]=0x1a;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
//el. Leistungsaufnahme WW Tag kWh
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x09;id(send_state)[4]=0x1b;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
if (id(el_aufnahmeleistung_ww_tag_kwh_flag) and id(el_aufnahmeleistung_ww_tag_wh_flag)){
id(el_aufnahmeleistung_ww_tag_kwh) += id(el_aufnahmeleistung_ww_tag_wh_float);
float daily_electric_energy_water=id(el_aufnahmeleistung_ww_tag_kwh);
id(el_aufnahmeleistung_ww_tag_kwh_flag)=false;
id(el_aufnahmeleistung_ww_tag_wh_flag)=false;
return daily_electric_energy_water;
else{return {};}
#name: "WM Heizung heute"
name: "Lämmityksen WM?? tänään"
icon: "mdi:water-boiler"
lambda: |-
//WM Heizen Tag wh
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x09;id(send_state)[4]=0x2e;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
//WM Heizen Tag kwh
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x09;id(send_state)[4]=0x2f;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
if (id(waermemertrag_heiz_tag_kwh_flag) and id(waermemertrag_heiz_tag_wh_flag)){
id(waermemertrag_heiz_tag_kwh) += id(waermemertrag_heiz_tag_wh_float);
float daily_heating_energy=id(waermemertrag_heiz_tag_kwh);
id(waermemertrag_heiz_tag_kwh_flag)=false;
id(waermemertrag_heiz_tag_wh_flag)=false;
return daily_heating_energy;
else {
return {};
#name: "Stromverbrauch Heizung heute"
name: "Sähkönkulutus lämmitys tänään"
lambda: |-
//el. Leistungsaufnahme Heizen Tag Wh
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x09;id(send_state)[4]=0x1e;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
//el. Leistungsaufnahme Heizen Tag kWh
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x09;id(send_state)[4]=0x1f;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
if (id(el_aufnahmeleistung_heiz_tag_kwh_flag) and id(el_aufnahmeleistung_heiz_tag_wh_flag)){
id(el_aufnahmeleistung_heiz_tag_kwh) += id(el_aufnahmeleistung_heiz_tag_wh_float);
float daily_electric_energy_heating=id(el_aufnahmeleistung_heiz_tag_kwh);
id(el_aufnahmeleistung_heiz_tag_kwh_flag)=false;
id(el_aufnahmeleistung_heiz_tag_wh_flag)=false;
return daily_electric_energy_heating;
else{return {};}
update_interval: 6h
#name: "WM Warmwasser heute"
name: "Lämpimän veden WM?? tänään"
lambda: |-
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x09;id(send_state)[4]=0x2a;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
id(send_state)[0]=0x31;id(send_state)[1]=0x00;id(send_state)[2]=0xfa;id(send_state)[3]=0x09;id(send_state)[4]=0x2b;id(send_state)[5]=0x00;id(send_state)[6]=0x00;
if (id(waermemertrag_ww_tag_kwh_flag) and id(waermemertrag_ww_tag_wh_flag)){
id(waermemertrag_ww_tag_kwh) += id(waermemertrag_ww_tag_wh_float);
float daily_heating_energy_water=id(waermemertrag_ww_tag_kwh);
id(waermemertrag_ww_tag_kwh_flag)=false;
id(waermemertrag_ww_tag_wh_flag)=false;
return daily_heating_energy_water;
else{ return {};
