I just connected an MCP2515 Can-Bus component with ESP Wroom 32 to my Stiebel-Eltron WPF07 Cool heating pump.
Basically I followed the instructions on the ESP-Home page
Then I have received some good starting instructions, where Vincent82 posted me his configuration how to use the config and there was also a lot of information on the homepage of juerg5524 regarding this heating pump.
I hereby share my current config.
Since I was struggling a lot with this device - maybe it will help someone
I still didn’t achieve to get an answer for compressor timings from any CAN-ID.
But I can now easily read out the electrical power consumption of my pump.
captive_portal:
globals:
- id: el_aufnahmeleistung_ww_tag_wh_float
type: float
restore_value: yes
- id: el_aufnahmeleistung_ww_tag_wh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_ww_tag_kwh
type: float
restore_value: yes
- id: el_aufnahmeleistung_ww_tag_kwh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_heiz_tag_wh_float
type: float
restore_value: yes
- id: el_aufnahmeleistung_heiz_tag_wh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_heiz_tag_kwh
type: float
restore_value: yes
- id: el_aufnahmeleistung_heiz_tag_kwh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_ww_total_kWh_float
type: float
restore_value: yes
- id: el_aufnahmeleistung_ww_total_kWh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_ww_total_mWh
type: float
restore_value: yes
- id: el_aufnahmeleistung_ww_total_mWh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_heiz_total_kWh_float
type: float
restore_value: yes
- id: el_aufnahmeleistung_heiz_total_kWh_flag
type: bool
restore_value: yes
- id: el_aufnahmeleistung_heiz_total_mWh
type: float
restore_value: yes
- id: el_aufnahmeleistung_heiz_total_mWh_flag
type: bool
restore_value: yes
- id: waermemertrag_ww_tag_wh_float
type: float
restore_value: yes
- id: waermemertrag_ww_tag_wh_flag
type: bool
restore_value: yes
- id: waermemertrag_ww_tag_kwh
type: float
restore_value: yes
- id: waermemertrag_ww_tag_kwh_flag
type: bool
- id: waermemertrag_electr_ww_tag_wh_float
type: float
restore_value: yes
- id: waermemertrag_electr_ww_tag_wh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_ww_tag_kwh
type: float
restore_value: yes
- id: waermemertrag_electr_ww_tag_kwh_flag
type: bool
restore_value: yes
- id: waermemertrag_heiz_tag_wh_float
type: float
restore_value: yes
- id: waermemertrag_heiz_tag_wh_flag
type: bool
restore_value: yes
- id: waermemertrag_heiz_tag_kwh
type: float
restore_value: yes
- id: waermemertrag_heiz_tag_kwh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_heiz_tag_wh_float
type: float
restore_value: yes
- id: waermemertrag_electr_heiz_tag_wh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_heiz_tag_kwh
type: float
restore_value: yes
- id: waermemertrag_electr_heiz_tag_kwh_flag
type: bool
restore_value: yes
- id: waermemertrag_ww_total_kWh_float
type: float
restore_value: yes
- id: waermemertrag_ww_total_kWh_flag
type: bool
restore_value: yes
- id: waermemertrag_ww_total_mWh
type: float
restore_value: yes
- id: waermemertrag_ww_total_mWh_flag
type: bool
restore_value: yes
- id: waermemertrag_heiz_total_kWh_float
type: float
restore_value: yes
- id: waermemertrag_heiz_total_kWh_flag
type: bool
restore_value: yes
- id: waermemertrag_heiz_total_mWh
type: float
restore_value: yes
- id: waermemertrag_heiz_total_mWh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_heiz_total_kWh_float
type: float
restore_value: yes
- id: waermemertrag_electr_heiz_total_kWh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_heiz_total_mWh
type: float
restore_value: yes
- id: waermemertrag_electr_heiz_total_mWh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_ww_total_kWh_float
type: float
restore_value: yes
- id: waermemertrag_electr_ww_total_kWh_flag
type: bool
restore_value: yes
- id: waermemertrag_electr_ww_total_mWh
type: float
restore_value: yes
- id: waermemertrag_electr_ww_total_mWh_flag
type: bool
restore_value: yes
unit_of_measurement: "°C"
icon: "mdi:thermometer-lines"
device_class: "temperature"
state_class: "measurement"
accuracy_decimals: 1
icon: "mdi:waves-arrow-right"
icon: "mdi:waves-arrow-left"
name: "Luftfeuchtigkeit Wohnraum"
unit_of_measurement: "%rH"
icon: "mdi:water-percent"
device_class: "humidity"
name: "Temperatur Wohnraum"
name: "Stromverbrauch Warmwasser heute"
unit_of_measurement: "kWh"
device_class: "energy"
accuracy_decimals: 3
icon: "mdi:transmission-tower"
name: "Stromverbrauch Heizung heute"
name: "Stromverbrauch Warmwasser total"
unit_of_measurement: "MWh"
name: "Stromverbrauch Heizung total"
name: "WM Heizung heute"
icon: "mdi:water-boiler"
name: "WM Heizen total"
name: "WM Warmwasser heute"
name: "WM Warmwasser total"
name: "WM elektr. Warmwasser total"
name: "WM elektr. heizen total"
binary_sensor:
time:
- platform: homeassistant
on_time:
- seconds: /180
then:
#WM NE WW Summe wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x22,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE WW Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x23,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE Heizen Summe wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x26,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM NE Heizen Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x27,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Tag wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2a,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Tag kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2b,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2c,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM WW Summe Mwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2d,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Tag wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2e,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Tag kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x2f,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x30,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WM Heizen Summe Mwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x31,0x00,0x00 ]
can_id: 0x680
- delay: 10s
- lambda: |-
if (id(waermemertrag_electr_ww_total_mWh_flag) and id(waermemertrag_electr_ww_total_kWh_flag)){
id(waermemertrag_electr_ww_total_mWh) += id(waermemertrag_electr_ww_total_kWh_float);
id(total_electric_heating_energy_water).publish_state(id(waermemertrag_electr_ww_total_mWh));
id(waermemertrag_electr_ww_total_mWh_flag)=false;
id(waermemertrag_electr_ww_total_kWh_flag)=false;
- lambda: |-
if (id(waermemertrag_electr_heiz_total_kWh_flag) and id(waermemertrag_electr_heiz_total_mWh_flag)){
id(waermemertrag_electr_heiz_total_mWh) += id(waermemertrag_electr_heiz_total_kWh_float);
id(total_electric_heating_energy).publish_state(id(waermemertrag_electr_heiz_total_mWh));
id(waermemertrag_electr_heiz_total_kWh_flag)=false;
id(waermemertrag_electr_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(waermemertrag_ww_total_mWh_flag) and id(waermemertrag_ww_total_kWh_flag)){
id(waermemertrag_ww_total_mWh) += id(waermemertrag_ww_total_kWh_float);
id(total_heating_energy_water).publish_state(id(waermemertrag_ww_total_mWh));
id(waermemertrag_ww_total_mWh_flag)=false;
id(waermemertrag_ww_total_kWh_flag)=false;
- lambda: |-
if (id(waermemertrag_heiz_total_kWh_flag) and id(waermemertrag_heiz_total_mWh_flag)){
id(waermemertrag_heiz_total_mWh) += id(waermemertrag_heiz_total_kWh_float);
id(total_heating_energy).publish_state(id(waermemertrag_heiz_total_mWh));
id(waermemertrag_heiz_total_kWh_flag)=false;
id(waermemertrag_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(waermemertrag_heiz_tag_kwh_flag) and id(waermemertrag_heiz_tag_wh_flag)){
id(waermemertrag_heiz_tag_kwh) += id(waermemertrag_heiz_tag_wh_float);
id(daily_heating_energy).publish_state(id(waermemertrag_heiz_tag_kwh));
id(waermemertrag_heiz_tag_kwh_flag)=false;
id(waermemertrag_heiz_tag_wh_flag)=false;
- lambda: |-
if (id(waermemertrag_ww_tag_kwh_flag) and id(waermemertrag_ww_tag_wh_flag)){
id(waermemertrag_ww_tag_kwh) += id(waermemertrag_ww_tag_wh_float);
id(daily_heating_energy_water).publish_state(id(waermemertrag_ww_tag_kwh));
id(waermemertrag_ww_tag_kwh_flag)=false;
id(waermemertrag_ww_tag_wh_flag)=false;
#el. Leistungsaufnahme WW Tag Wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1a,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme WW Tag kWh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1b,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme WW Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1c,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme WW Summe Mwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1d,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme Heizen Tag Wh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1e,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x1f,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme Heizen Summe kwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x20,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#el. Leistungsaufnahme Heizen Summe Mwh - ok
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x09,0x21,0x00,0x00 ]
can_id: 0x680
- delay: 10s
- lambda: |-
if (id(el_aufnahmeleistung_ww_total_mWh_flag) and id(el_aufnahmeleistung_ww_total_kWh_flag)){
id(el_aufnahmeleistung_ww_total_mWh) += id(el_aufnahmeleistung_ww_total_kWh_float);
id(total_electric_energy_water).publish_state(id(el_aufnahmeleistung_ww_total_mWh));
id(el_aufnahmeleistung_ww_total_mWh_flag)=false;
id(el_aufnahmeleistung_ww_total_kWh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_heiz_total_mWh_flag) and id(el_aufnahmeleistung_heiz_total_kWh_flag)){
id(el_aufnahmeleistung_heiz_total_mWh) += id(el_aufnahmeleistung_heiz_total_kWh_float);
id(total_electric_energy_heating).publish_state(id(el_aufnahmeleistung_heiz_total_mWh));
id(el_aufnahmeleistung_heiz_total_mWh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_ww_tag_kwh_flag) and id(el_aufnahmeleistung_ww_tag_wh_flag)){
id(el_aufnahmeleistung_ww_tag_kwh) += id(el_aufnahmeleistung_ww_tag_wh_float);
id(daily_electric_energy_water).publish_state(id(el_aufnahmeleistung_ww_tag_kwh));
id(el_aufnahmeleistung_ww_tag_kwh_flag)=false;
id(el_aufnahmeleistung_ww_tag_wh_flag)=false;
- lambda: |-
if (id(el_aufnahmeleistung_heiz_tag_kwh_flag) and id(el_aufnahmeleistung_heiz_tag_wh_flag)){
id(el_aufnahmeleistung_heiz_tag_kwh) += id(el_aufnahmeleistung_heiz_tag_wh_float);
id(daily_electric_energy_heating).publish_state(id(el_aufnahmeleistung_heiz_tag_kwh));
id(el_aufnahmeleistung_heiz_tag_kwh_flag)=false;
id(el_aufnahmeleistung_heiz_tag_wh_flag)=false;
- lambda: |-
ESP_LOGD("main", "EVU Sperre requested");
#Außentemperatur 1/10 °C et dec value - ok /10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x0c,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#Vorlauftemperatur - ok 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x0d,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#Vorlauftemperatur Hzg - ok 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x0f,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#Rücklauftemperatur Hzg - ok 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x16,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#WW Temperatur - ok + offset
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x00,0x0e,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
#Quelle IST: - ok 1/10
- canbus.send:
data: [ 0x31, 0x00, 0xfa,0x01,0xd4,0x00,0x00 ]
can_id: 0x680
- delay: 200ms
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
canbus:
- platform: mcp2515
spi_id: McpSpi
cs_pin: GPIO15
can_id: 680
use_extended_id: false
bit_rate: 20kbps
on_frame:
#Warmwasser-Temperaturabfrage + Offset 3.9 °C
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x0e) {
float temperature =float((float((int((x[6])+( (x[5])<<8))))/10)+3.9);
id(temperature_water).publish_state(temperature);
ESP_LOGD("main", "Temperature received over can is %f", temperature);
#Quellen-Temperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x01 and x[4] == 0xd4) {
float temperature =float(float((int((x[6])+( (x[5])<<8))))/10);
id(temperature_source).publish_state(temperature);
#Vorlauftemperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x0d) {
float temperature =float(float((int((x[6])+( (x[5])<<8))))/1000);
id(temperature_forerun).publish_state(temperature);
#Vorlauftemperaturabfrage Heizkreis
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x0f) {
id(temperature_forerun_heating).publish_state(temperature);
#Rücklauftemperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x16) {
id(temperature_return).publish_state(temperature);
#Außentemperaturabfrage
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[3]==0x00 and x[4] == 0x0c) {
id(temperature_outside).publish_state(temperature);
#Luftfeuchtigkeit FEK mitlesen
- can_id: 0x301
then:
- lambda: |-
if(x[0]==0xc0 and x[1]==0x01 and x[2]==0x75) {
float humidity =float(float((int((x[4])+( (x[3])<<8))))/10);
id(humidity_inside).publish_state(humidity);
ESP_LOGD("main", "Humidity received over can is %f", humidity);
#Raumtemperatur FEK mitlesen
- can_id: 0x301
then:
- lambda: |-
if(x[0]==0xc0 and x[1]==0x01 and x[2]==0x11) {
float temperature =float(float((int((x[4])+( (x[3])<<8))))/10);
id(temperature_inside).publish_state(temperature);
#Elektrische Leistungsaufnahme Wh /kWh
- can_id: 0x180
then:
- lambda: |-
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0xfa and x[3]==0x09) {
if (x[4]==0x1a){
id(el_aufnahmeleistung_ww_tag_wh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_ww_tag_wh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_tag_kwh received over can is %f", id(el_aufnahmeleistung_ww_tag_wh_float));}
else if (x[4]==0x1e){
id(el_aufnahmeleistung_heiz_tag_wh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_heiz_tag_wh_flag) = true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_tag_wh received over can is %f", id(el_aufnahmeleistung_heiz_tag_wh_float));}
else if (x[4]==0x1c){
id(el_aufnahmeleistung_ww_total_kWh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_ww_total_kWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_total_kkWh received over can is %f", id(el_aufnahmeleistung_ww_total_kWh_float));}
else if (x[4]==0x20){
id(el_aufnahmeleistung_heiz_total_kWh_float) = (float((int((x[6])+( (x[5])<<8))))/1000);
id(el_aufnahmeleistung_heiz_total_kWh_flag) = true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_total_kWh received over can is %f", id(el_aufnahmeleistung_heiz_total_kWh_float));}
if(x[0]==0xd2 and x[1]==0x00 and x[2]==0xfa and x[3]==0x00 and x[4]==0x74){
if(x[5]==0x80 and x[6]==0x00){
id(evu_lock).publish_state(false);
else{
id(evu_lock).publish_state(true);
#Elektrische Leistungsaufnahme kWh / MWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x1b){
id(el_aufnahmeleistung_ww_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_ww_tag_kwh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_tag_kwh received over can is %f", id(el_aufnahmeleistung_ww_tag_kwh));}
else if(x[4]==0x1f){
id(el_aufnahmeleistung_heiz_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_heiz_tag_kwh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_tag_kwh received over can is %f", id(el_aufnahmeleistung_heiz_tag_kwh));}
else if(x[4]==0x1d){
id(el_aufnahmeleistung_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_ww_total_mWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_ww_total_mWh received over can is %f", id(el_aufnahmeleistung_ww_total_mWh));}
else if(x[4]==0x21){
id(el_aufnahmeleistung_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(el_aufnahmeleistung_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "el_aufnahmeleistung_heiz_total_mWh received over can is %f", id(el_aufnahmeleistung_heiz_total_mWh));}
#Wärmeertrag WW/Heizung MWh / kWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x23){
id(waermemertrag_electr_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_electr_ww_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_ww_tag_kwh received over can is %f", id(waermemertrag_electr_ww_total_mWh));}
else if(x[4]==0x27){
id(waermemertrag_electr_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_electr_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_heiz_tag_kwh received over can is %f", id(waermemertrag_electr_heiz_total_mWh));}
else if(x[4]==0x2b){
id(waermemertrag_ww_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_ww_tag_kwh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_tag_kwh received over can is %f", id(waermemertrag_ww_tag_kwh));}
else if(x[4]==0x2d){
id(waermemertrag_ww_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_ww_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_total_mWh received over can is %f", id(waermemertrag_ww_total_mWh));}
else if(x[4]==0x2f){
id(waermemertrag_heiz_tag_kwh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_heiz_tag_kwh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_tag_kwh received over can is %f", id(waermemertrag_heiz_tag_kwh));}
else if(x[4]==0x31){
id(waermemertrag_heiz_total_mWh) =float(int((x[6])+( (x[5])<<8)));
id(waermemertrag_heiz_total_mWh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_total_kWh_float received over can is %f", id(waermemertrag_heiz_total_mWh));}
#Wärmeertrag WW/Heizung Wh / kWH
- can_id: 0x180
then:
- lambda: |-
if(x[4]==0x22){
id(waermemertrag_electr_ww_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_electr_ww_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_ww_tag_wh_float received over can is %f", id(waermemertrag_electr_ww_total_kWh_float));}
else if(x[4]==0x26){
id(waermemertrag_electr_heiz_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_electr_heiz_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_electr_heiz_tag_wh_float received over can is %f", id(waermemertrag_electr_heiz_total_kWh_float));}
else if(x[4]==0x2a){
id(waermemertrag_ww_tag_wh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_ww_tag_wh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_tag_wh_float received over can is %f", id(waermemertrag_ww_tag_wh_float));}
else if(x[4]==0x2c){
id(waermemertrag_ww_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_ww_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_ww_total_kWh_float received over can is %f", id(waermemertrag_ww_total_kWh_float));}
else if(x[4]==0x2e){
id(waermemertrag_heiz_tag_wh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_heiz_tag_wh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_tag_wh_float received over can is %f", id(waermemertrag_heiz_tag_wh_float));}
else if(x[4]==0x30){
id(waermemertrag_heiz_total_kWh_float) =float(int((x[6])+( (x[5])<<8)))/1000;
id(waermemertrag_heiz_total_kWh_flag)=true;
ESP_LOGD("main", "waermemertrag_heiz_total_kWh_float received over can is %f", id(waermemertrag_heiz_total_kWh_float));}
#Show data in raw form as hex-values
- can_id: 0x180
then:
- lambda: |-
int wert0 = int(x[0]);
int wert1 =int(x[1]);
int wert2 =int(x[2]);
int wert3 =int(x[3]);
int wert4 =int(x[4]);
int wert5 =int(x[5]);
int wert6 =int(x[6]);
float wert7 = float(int((x[6])+( (x[5])<<8)));
ESP_LOGD("main", "Antwort von 180 Hex: %x %x %x %x %x %x %x", wert0, wert1, wert2, wert3, wert4, wert5, wert6);
ESP_LOGD("main", "Antwort von 180 Float: %f", wert7);
ESP_LOGD("main", "Antwort von 180 Dez.: %i %i", wert5, wert6);
