Configuring a physical button to update a virtual switch
I have the following device configuration using the esphome integration
esphome:
  platform: ESP8266
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: !secret ota_password
wifi:
  ssid: "MyHotspot"
  ap:
    ssid: "Are-You-Home-Fallback-Hotspot"
    password: !secret fallback_password
captive_portal:
switch:
- platform: gpio
  pin:
      number: 0
      inverted: true
  optimistic: yes
  turn_on_action:
  - while:
      condition:
        lambda: 'return true;'
      then:
      - switch.turn_on: are_you_home_siren
      - delay: 500ms
      - switch.turn_off: are_you_home_siren
      - delay: 500ms
  turn_off_action:
binary_sensor:
- platform: gpio
  pin:
    number: 3
    mode: INPUT_PULLUP
  device_class: sound
That provides the following device entities
The device it controls has a piezo buzzer and a momentary switch. The beeping alarm triggers just fine when the switch is toggled in the HASS devices dashboard. When the physical momentary button is pushed the HASS devices dashboard reflects this by putting a line through the note and changing “detected” to “clear”.
What I am wanting to do is to link the two together i.e. when the physical button is pressed, if the buzzer is beeping, then Siren toggle on the dashboard changes to off and the sound stops.
I am not sure where to begin with this.
You need to give your button instructions on what to do by adding an automation to your gpio binary sensor, such as “on-press” or “on-release”…
esphome:
  platform: ESP8266
  board: esp01_1m
# Enable logging
logger:
api:
ota:
wifi:
  ssid: "MyHotspot"
  ap:
captive_portal:
switch:
- platform: gpio
  pin:
      number: 0
      inverted: true
  optimistic: yes
  turn_on_action:
  - while:
      condition:
      then:
      - delay: 500ms
      - delay: 500ms
  turn_off_action:
binary_sensor:
- platform: gpio
  pin:
    number: 3
    mode: INPUT_PULLUP
  device_class: sound
  on_press:
      then:
        - switch.turn_off: sirentemp
You could use switch.toggle instead if you wanted to be able to trigger the siren by pressing the button.
Since the button itself is not detecting sound I would leave its device class as default, not sound. But it won’t hurt anything to have the device class that way, it will just make your state appear as “detected/clear” in the frontend instead of “on/off”.
If you don’t actually need to see the button’s entity in Home Assistant, you can also add “internal: true”.
Thanks, that was perfect. For completeness sake, here is the final code:
esphome:
  platform: ESP8266
  board: esp01_1m
# Enable logging
logger:
api:
ota:
wifi:
  ssid: "MyHotspot"
  ap:
captive_portal:
switch:
- platform: gpio
  pin:
      number: 0
      inverted: true
  optimistic: yes
  turn_on_action:
  - while:
      condition:
      then:
      - delay: 500ms
      - delay: 500ms
  turn_off_action:
binary_sensor:
- platform: gpio
  pin:
    number: 3
    mode: INPUT_PULLUP
  internal: true
  #device_class: sound
  on_press:
    then:
For my final project please see the following: https://www.instructables.com/Anyone-Home/ (see step 4 at end for HASS integration steps).
