Configuring Adguard in Home assitant
Hoping someone can help me. I added Adguard and am able to access it through HA. The problem I’m having is how to configure the IP address. It says no clients connected. I tried individually adding clients and adding my router, nothing seems to work. I do not have a static IP address and understand that if it changes for my router it wouldn’t work. I do have a reserved address for my HA though, 192.169.1.50. So I figured that was what I was supposed to add to other computers or my router as a DNS. This does nothing though. What am I doing wrong? Or is it as simple as I need to get a static IP address from my service provider?
Thanks!
You need to change your dns server in your router and any other devices that are manually configured to the address of home assistant. That’s all. Just search how to change dns with your router model if you’re not familiar.
I’ve done that, I put in the IP address for the HA in as the DNS. It didn’t work. Is that not what you’re referring to?
It should be the only dns ip number entered under dns servers. If it is the only number under dns servers and you can connect web pages then it is working. You must have a dns server in order to visit a page like google.com.
