Hi all,
I keep getting the following error in my logs and I am unsure of what is causing it. I have only recently started using Hassio which is installed on a rasp pi 3B+
2019-08-09 11:55:28 WARNING (MainThread) [homeassistant.components.http] Configuring api_password via the http integration has been deprecated. Use the legacy api password auth provider instead. For instructions, see https://www.home-assistant.io/docs/authentication/providers/#legacy-api-password
2019-08-09 11:55:28 WARNING (MainThread) [homeassistant.components.http.auth] legacy_api_password support has been enabled.
2019-08-09 11:55:29 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=19 from 2019-08-06 13:19:12.753096)
2019-08-09 11:55:32 ERROR (SyncWorker_1) [homeassistant.components.bom.weather] Could not get BOM weather station from lat/lon
2019-08-09 11:56:29 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.20.1
2019-08-09 11:56:30 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.20.1
2019-08-09 12:07:50 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
File "uvloop/sslproto.pyx", line 500, in uvloop.loop.SSLProtocol._on_handshake_complete
File "uvloop/sslproto.pyx", line 484, in uvloop.loop.SSLProtocol._do_handshake
File "/usr/local/lib/python3.7/ssl.py", line 774, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: VERSION_TOO_LOW] version too low (_ssl.c:1076)
2019-08-09 12:08:15 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
ssl.SSLError: [SSL: NO_SHARED_CIPHER] no shared cipher (_ssl.c:1076)
2019-08-09 12:15:40 WARNING (zeroconf-ServiceBrowser__googlecast._tcp.local.) [zeroconf] Exception occurred:
File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 2245, in send
bytes_sent = s.sendto(packet, 0, (addr, port))
PermissionError: [Errno 1] Operation not permitted
The very first error tells you exactly where to go to fix it. You have also possibly locked yourself out - do you have an ip_bans.yaml file in the config folder?
Ok - Ive updated the config.yaml with auth_providers.
But I do not have ip_bans.yaml in my config folder.
Ok… so is it working now then? If not post your config as a start
I thought it was working as it removed the error when I validated the config. But now when I log in it gets stuck on “initialising” in the Hassio web interface. I think my lines in the config.yaml are out of whack… Thanks for your help so far!
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
auth_providers:
- type: homeassistant
- type: legacy_api_password
latitude: !secret latitude
longitude: !secret longitude
elevation: 23
unit_system: metric
time_zone: Australia/Perth
#whitelist_external_dirs:
# - /usr/var/dumping-ground
# - /tmp
#Weather from Australian Bureau of Meteorology (BOM)
weather:
- platform: bom
#camera:
# - platform: bom
# location: Perth
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
http:
#Secrets are defined in the secrets.yaml file
api_password: !secret http_password
base_url: https://<mydomain>.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
do you already have duckdns/ssl setup? Also remove the api_password from http: section. If you don’t have ssl and duckdns setup, comment out thoise lines as well.
Yes, I do have DuckDNS and SSL setup. So is that the issue? I haven’t commented out those lines yet.
if they are setup it shouldn’t be an issue but the api_password under http might be.
Is this a new setup?
What settings have you made on your router (port forwarding)?
Yes this is a new set up - few days old. Should I comment out the api_password line?
I have set up port forwarding for 443 and 8123
only the one under http: section.
how did you setup ssl and duckdns?
Hmmm still won’t let me get in. Maybe I need to restart by turning it off and on manually.
Set up SSL and duckdns following different youtube videos (JuanMTech)
yeah try commenting out the base url and ssl lines and see if you can get in via the ipaddress:8123
eliminate ssl as the reason for the errors anyway
Looks like you need an extra space before each hyphen under auth_providers
yeah it does. I missed that.
No problem, glad to help.
Sometimes the problem can be right.under our noses
