Also
is it mandatory to put into configuration.yaml the following… or not?
command_line: !include command_line.yaml
Also
I am unable to get this working. I am only able to get the CPU temperature sensor working with command_line, for the rest, it error’s out.
Please help. My sensor’s part from configuration.yaml are below:
-sensor:
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: /config
- type: disk_use
- type: disk_free
- type: memory_use_percent
- type: memory_use
- type: memory_free
- type: swap_use_percent
- type: swap_use
- type: swap_free
- type: load_1m
- type: load_5m
- type: load_15m
- type: network_in
arg: eth0
- type: network_out
arg: eth0
- type: throughput_network_in
arg: eth0
- type: throughput_network_out
arg: eth0
- type: packets_in
arg: eth0
- type: packets_out
arg: eth0
- type: ipv4_address
arg: eth0
- type: ipv6_address
arg: eth0
- type: processor_use
- type: processor_temperature
- type: last_boot
sensors:
A1_phone_home:
value_template: >-
{% if states('sensor.A1_device_wifi_connection') == "wifi_home-5G" %}
home
{% elif states('sensor.A1_device_wifi_connection') == "wifi_home" %}
home
{% else %}
not_home
{% endif %}
friendly_name: "A1_phone_wifi"
G1_phone_home:
value_template: >-
{% if states('sensor.G1_phone_wifi_connection') == "wifi_home-5G" %}
home
{% elif states('sensor.G1_phone_wifi_connection') == "wifi_home" %}
home
{% else %}
not_home
{% endif %}
friendly_name: "G1_phone_wifi"
- platform: command_line
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: "{{ value | multiply(0.001) | round(1) }}"
scan_interval: 10
Thank you
That is not a command line sensor. Leave it where it is,
Not. It is only required if you want to split your config into different files.
Thank you for the reply. I get an error when i put that in configuration.yaml.
i followed System Monitor - Home Assistant link and it has been declared as a sensor.
If i keep it as is, it gives me the below error.
Invalid config for [command_line]: required key not provided @ data[‘command_line’][1][‘sensor’][‘command’]. Got None. (See /config/configuration.yaml, line 49).
Integration error: -sensor - Integration ‘-sensor’ not found.
It works!!
had to add
and use this code into command_line.yaml
- sensor:
value_template: '{{ value | multiply(0.001) | round(2) }}'```
Worked for me thanks !
Thanks for your help!
Any ideas how to make this work with command_line?
switch:
- platform: rpi_gpio
ports:
23: Tehnoruum
invert_logic: true
That is not a command line switch. Leave it as is.
Jag fick meddelandet ‘Command Line YAML configuration has moved’.
In configuration.yaml, I had:
name: Raspberry CPU Temperature
command: cat /sys/class/thermal/thermal_zone0/temp
value_template: "{{ value | multiply(0.001) | round(2) }}"
I changed it to:
- command_line: (here I see Missing Property "platform".
- sensor:
And when using Developer tools Check Configuration, I see:
Configuration invalid!
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 27).
Can someone please help me out and tell me what I am doing wrong?
Should be
command_line:
And the command line integration should be in your configuration.yaml file. Not the sensors.yaml file.
Thanks for responding. I now have:
command_line:
- sensor:
And I see:
Invalid config for [command_line]: [platform] is an invalid option for [command_line]. Check: command_line->command_line->1->platform. (See /config/configuration.yaml, line 52).
Notes:
Everything is in configuration.yaml. I do not have a sensors.yaml file.
To clarify, I am also including a screenshot of this section of configuration.yaml, just in case:
Thanks again.
Remove all of the text under your circled text that starts - platform: systemmonitor... and ends before input_select:...
That is not a command line sensor and belongs under sensor: in your configuration.yaml file.
Also in future please do not post images of text. Post the text correctly formatted for the forum.
Thank you. Sorted.
Noted and acknowledged re. images.
The notification says Command Line YAML configuration has moved, but it doesn’t say from-where or where-to. Many users probably still have their sensor section in their configuration.yaml file, hence the Command Line YAML configuration hasn’t moved anywhere - it has just changed. I think therefore the headline is misleading. It would also be nice if the DOCs would mention that the old syntax for command_line has been (will be) depreciated;
The configuration has moved. From the sensor integration to its own integration. That does not depend on you having a split config or not.
Yeah, I guess you are right. I can see that now, but it wasn’t immediately obvious to me what was meant by that headline.
Thanks for enlightening me.
This works for me too.
Unfortunately I have to adjust all my template sensors to the command_line.
I’ve split up my configuration.yaml and now added :
Integrations:
Command_line.yaml
command_line: !include_dir_merge_list ../entities/command_line
In the folder ‘Entities\command_line’
I have several files like this : (uset to be located in my ‘sensor’ subfolder)
sensors:
energy_import_totaal_dagelijks_kwh:
friendly_name: 'kWh vandaag piek + dal'
value_template: "{{ (states('sensor.energy_import_t1_dagelijks_kwh')|float + states('sensor.energy_import_t2_dagelijks_kwh')|float)|round(2) }}"
unit_of_measurement: "kWh"
sensors:
energy_import_totaal_wekelijks_kwh:
friendly_name: 'kWh wekelijks piek + dal'
value_template: "{{ (states('sensor.energy_import_t1_wekelijks_kwh')|float + states('sensor.energy_import_t2_wekelijks_kwh')|float)|round(2) }}"
sensors:
energy_import_totaal_maandelijks_kwh:
friendly_name: 'kWh maandelijks piek + dal'
value_template: "{{ (states('sensor.energy_import_t1_maandelijks_kwh')|float + states('sensor.energy_import_t2_maandelijks_kwh')|float)|round(2) }}"
etc....
Can someone help me and tell me how to ‘convert’ these sensors templates to command_line ?
Thanks in advance.
Jeffrey
