juscode
(Jas)
June 7, 2023, 8:39pm
1
Getting this error after upgrade:
Configuring Command Line sensor using YAML has moved.
Consult the documentation to move your YAML configuration to integration key and restart Home Assistant to fix this issue.
This is my sensors.yaml:
platform: template
sensors:
battery_level:
friendly_name: Battery Level
value_template: >-
{% set batterylevel = (states(‘sensor.solaredge_battery1_state_of_charge’)|float +
states(‘sensor.solaredge_battery2_state_of_charge’)|float) / 2 %}
{{ ‘{:.1f}’.format(batterylevel) }}
unit_of_measurement: “%”
battery_power:
friendly_name: Battery Power Total
value_template: >-
{% set batterypower = (states(‘sensor.solaredge_battery1_power’)|float +
states(‘sensor.solaredge_battery2_power’)|float) %}
{{ ‘{:.0f}’.format(batterypower) }}
unit_of_measurement: “W”
battery_power_negative:
friendly_name: Battery Negative
value_template: >-
{% set batterypowerneg = -1 * (states(‘sensor.solaredge_battery1_power’)|float +
states(‘sensor.solaredge_battery2_power’)|float) |float(0) %}
{{ ‘{:.0f}’.format(batterypowerneg) }}
grid_power_negative:
friendly_name: Grid Negative
value_template: >-
{% set gridneg = -1 * states(‘sensor.solaredge_m1_ac_power’) |float(0) %}
{{ ‘{:.0f}’.format(gridneg) }}
total_power:
friendly_name: Solar Generation
value_template: >-
{% if states(‘sensor.solaredge_battery1_status’) == ‘Discharging’ %}
{% set totalpower = ((states(‘sensor.solaredge_battery1_power’)|float +
states(‘sensor.solaredge_battery2_power’)|float) + states(‘sensor.solaredge_dc_power’)|float) %}
{{ ‘{:.1f}’.format(totalpower) }}
{% else %}
{% set totalpower = (states(‘sensor.solaredge_battery1_power’)|float +
states(‘sensor.solaredge_battery2_power’)|float + states(‘sensor.solaredge_dc_power’)|float) %}
{% endif %}
house_cons:
friendly_name: House Consumption
value_template: >-
{% if states(‘sensor.solaredge_m1_ac_power’)|float > 1 %}
{% set housecons = states(‘sensor.solaredge_ac_power’)|float -
states(‘sensor.solaredge_m1_ac_power’)|float %}
{{ ‘{:.0f}’.format(housecons) }}
{% else %}
{% set housecons = states(‘sensor.solaredge_ac_power’)|float %}
{% endif %}
energy_grid_import:
friendly_name: Grid Import Energy Sensor
value_template: >-
{% if states(‘sensor.solaredge_m1_ac_power’)|float < 0 %}
{% set energygridimport = states(‘sensor.solaredge_m1_ac_power’)|float |abs %}
{{ ‘{:.1f}’.format(energygridimport) }}
{% else %}
{% set energygridimport = 0 %}
{% endif %}
energy_grid_import_new:
friendly_name: Grid Import Energy Sensor New
value_template: >-
{% if states(‘sensor.solaredge_m1_ac_power’)|float > 0 %}
{% set energygridimportnew = 0 %}
{{ ‘{:.1f}’.format(energygridimportnew) }}
{% else %}
{% set energygridimportnew = states(‘sensor.solaredge_m1_ac_power’)|float |abs %}
{% endif %}
energy_grid_export:
friendly_name: Grid Export Energy Sensor
value_template: >-
{% set energygridexport = states(‘sensor.solaredge_m1_ac_power’)|float %}
{{ ‘{:.1f}’.format(energygridexport) }}
{% else %}
{% set energygridexport = 0 %}
{% endif %}
energy_grid_export_new:
value_template: >-
{% set energygridexportnew = states(‘sensor.solaredge_m1_ac_power’)|float %}
{{ ‘{:.1f}’.format(energygridexportnew) }}
{% else %}
{% set energygridexportnew = 0 %}
{% endif %}
energy_battery_charge:
friendly_name: Battery Charge
value_template: >-
{% if states(‘sensor.battery_power’)|float > 0 %}
{% set batterycharge = states(‘sensor.battery_power’)|float %}
{{ ‘{:.1f}’.format(batterycharge) }}
{% else %}
{% set batterycharge = 0 %}
{% endif %}
energy_battery_discharge:
friendly_name: Battery Discharge
value_template: >-
{% if states(‘sensor.battery_power’)|float < 0 %}
{% set batterydischarge = states(‘sensor.battery_power’)|float |abs %}
{{ ‘{:.1f}’.format(batterydischarge) }}
{% else %}
{% set batterydischarge = 0 %}
{% endif %}
platform: command_line
name: CPU Temperature
command: “cat /sys/class/thermal/thermal_zone0/temp”
unit_of_measurement: “°C”
value_template: ‘{{ value | multiply(0.001) | round(2) }}’
Would greatly appreciate any help to get it working am quite new to HA.
beecho01
(James Beeching)
June 7, 2023, 9:15pm
2
I believe that the command line sensor may be tripping you up here.
I think it should now be:
command_line:
- sensor:
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: "{{ value | multiply(0.001) | round(2) }}"
See here for updated layout: https://www.home-assistant.io/integrations/command_line/#cpu-temperature
DrewXT
(Andrew)
June 7, 2023, 11:31pm
3
this has me stumped as well - I have the following in my sensors.yaml, which I think per the documentation is correct? Yet I’m getting the same error as Jas is
- platform: command_line
name: "CPU Temperature"
value_template: '{{ value | multiply(0.001) | round(1) }}'
sensors:
disk_total:
value_template: "{{ ( states('sensor.disk_use')|float + states('sensor.disk_free')|float )| round (1) }}"
name: Host Operating System
command: 'curl http://supervisor/host/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''.data.operating_system'' | sed ''s/"//g'''
command: 'curl http://supervisor/supervisor/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version,"update_available":.data.update_available,"addons":[.data.addons[] | select(.update_available)]}'''
value_template: "{{ value_json.addons | length }}"
unit_of_measurement: pending update(s)
json_attributes:
- update_available
- newest_version
- current_version
- addons
Same here. This is in my sensor.yaml file:
# update the lastest ABC News Podcast
name: Latest ABC News Bulletin
scan_interval: 3600 # Every hour
command: curl -k -s https://www.abc.net.au/feeds/101858056/podcast.xml | grep -E -o 'https?://[^"]+mp3' | uniq | head -n 1
Maybe I need quotes around the command: element.
tom_l
June 8, 2023, 12:41am
5
No that is not correct. You have to move all your command line sensors.
configuration.yaml
command_line:
- sensor:
- sensor:
- sensor:
json_attributes:
- update_available
- newest_version
- current_version
- addons
You can use an include if you want. e.g.
command_line: !include command_line.yaml
Then everything above, except the first line “command_line:” goes in command_line.yaml instead of configuration.yaml
Note: you no longer need that last sensor. It is all provided by the supervisor integration.
I am getting same thing as OP. When i tried creating a command_line.yaml and add it to the config yaml i get this error
Configuration invalid!
Invalid config for [command_line]: expected a dictionary for dictionary value @ data[‘command_line’][0][‘sensor’]. Got None extra keys not allowed @ data[‘command_line’][0][‘command’]. Got ‘cat /sys/class/thermal/thermal_zone2/temp’ extra keys not allowed @ data[‘command_line’][0][‘name’]. Got ‘CPU Temp’ extra keys not allowed @ data[‘command_line’][0][‘unit_of_measurement’]. Got ‘°C’ extra keys not allowed @ data[‘command_line’][0][‘value_template’]. Got ‘{{ value | multiply(0.001) | round(1) }}’. (See /config/configuration.yaml, line 19).
if i add the command back into my sensors.yaml atm it all works fine still…
Javierpal
(Francisco Javier Hernandez Angeles)
June 8, 2023, 3:53am
7
samo samo with my configurations…
extra keys not allowed @ data['command_line'][0]['command']. Got 'cat /sys/class/thermal/thermal_zone0/temp'
extra keys not allowed @ data['command_line'][0]['name']. Got 'CPU Temperature'
extra keys not allowed @ data['command_line'][0]['unit_of_measurement']. Got '°C'
extra keys not allowed @ data['command_line'][0]['value_template']. Got '{{ value | multiply(0.001) | round(1) }}'. (See /config/configuration.yaml, line 220).
ew-ewim
(Wim)
June 8, 2023, 3:56am
8
The command line syntax describes that you should use prover indentation. In the cpu example for instance move every line after sensor 2 spaces to the right
tom_l
June 8, 2023, 4:03am
9
Thanks I updated my post.
aaron420
(Aaron)
June 8, 2023, 4:34am
10
awesome that did it… thanks
Javierpal
June 8, 2023, 4:48am
11
yeap it worked, I only put 2 more spaces after sensor line and it worked.
Subia75
(Alessio)
June 8, 2023, 9:35am
12
I have a question.
I have the sensors in a yaml file in the packages folder still written with the old format.
Do I need to move them to a dedicated file like the example one (command_line.yaml)?
or is it enough to rewrite them in the modern format?
eg.
# my old format
command: 'curl http://supervisor/supervisor/info -H "Authorization: Bearer $(printenv ............
etc....
# on new format
command_line:
- sensor:
etc.....
tom_l
June 8, 2023, 9:57am
13
Should be enough to rewrite them as you have done in your example. However… I don’t know if anyone tested packages during the beta trial. Let us know how it goes.
Subia75
(Alessio)
June 8, 2023, 10:03am
14
if I tried earlier I would have saved a question, however yes with the new format everything works even in the packages.
you always learn something.
spanzetta
(Stefano Panzetta)
June 8, 2023, 10:45am
15
Sorry but I am confused…
I moved the (still working) following code from “configuration.yaml ” (this morning aftet the update I was getting the warning about new format):
value_template: '{{ value | multiply(0.001) | round(2) }}'
to this new code into the new created file “command_line.yaml ”
- sensor:
but the CPU temp sensor doesn’t work anymore…
What’s wrong?
Can anyone help me with converting my sensors into the right format
sensors:
persons_at_home:
friendly_name: 'People At Home'
value_template: >
{{states.person|selectattr('state', '==', 'home')|list|count}}
sensors:
radiators_on:
friendly_name: 'Radiators On'
value_template: >
{{ [states.input_boolean.master_bedroom_radiator, states.input_boolean.office_radiator, states.input_boolean.living_room_radiator, states.input_boolean.kitchen_radiator, states.input_boolean.dinning_room_radiator]| selectattr('state', '==', 'on') | list | count }}
Why does everything have to change all the time?
You have invested a lot of time to arrange certain things well and thoughtfully and then you can reinvent everything again
DrewXT
(Andrew)
June 8, 2023, 11:00am
18
thanks Tom - worked like a charm
DrewXT
(Andrew)
June 8, 2023, 11:02am
19
try this for the temp sensor in command_line.yaml
spanzetta
(Stefano Panzetta)
June 8, 2023, 11:33am
20
Thanks… will try soon
But… should i put the 1st line (command_line) or not?
# on new format
command_line: <- this one???
- sensor:
xxxxxxx
