I recently bought a Aqara Motion Sensor and a Conbee2 stick and was having trouble getting it configured with VirtualBox and Windows. I couldn’t find any direct guides but pieced together enough to get it working. Thought I’d share in case anyone else hits the same issue.
Update virtual box to the latest
Download and install the VirtualBox Extension Pack from their website
Open Windows Control Panel, and go to Devices and Printers
Find the USB Device that is the Conbee (some plugging/unplugging can be helpful here)
Find it’s COM#, COM1, COM2, etc (mine was COM3)
Go into the VirtualBox config for your HASS instance, go to Serial Ports, check to enable, set Port Number to COM3 (I couldn’t get COM1 or COM2 to work), Mode to Host Device, and Path to COM# (whatever you found above)
Start up the virtual box node
Go to Config > Integrations in HASS and setup ZHA, the serial port should load but it’s probably /dev/ttyS2
Setup your Aqara, etc sensors by hitting configure under the ZHA integration and then clicking “Add device” in the bottom right. My Aqara motion sensor needed a 5s tap on it’s reset button to start flashing and register
Just in case anyone else is still having an issue with this, I had the same issue and the above solution wouldn’t work for me.
Same setup - I’ve got HA running on Windows 10 (on an HP ProDesk 600 G6) via VirtualBox, the Conbee II came up as a COM4 on PORTS>COM&LPT and nothing I did would get it to connect. When trying the above solution I couldn’t get it to connect, kept getting “Failed to open host device” no matter what path or COM port I put in. Spent way too much time trying various things.
Then I was taking a wee break for a much needed coffee, and the USB tab from VirtualBox config for my HASS instance was on the screen and I thought to myself “why isn’t the Conbee showing up on that list?”. I mean, it should.
Thinking, haha, this is stupid, I clicked on the wee icon for “Adds new USB filter…” and the damn Conbee was sitting right there. Selected it, restarted the virtual box node, went to HASS, added the ZHA integration through configure and I didn’t need to do anything other than select the Conbee which was autodetected.
I felt really stupid, but at least it’s solved - and maybe I can save someone else from wasting an hour and feeling dumb!
Just to add to this, I was having some issues getting it detected too after doing all of the above (and some other unspeakable things) with no luck. eventually I just started poking around the virtualbox menus, found the list of usb devices for my computer, and noticed the entry for the conbee III wasn’t ticked… so I ticked it, and now I’m off to the races:
