limouzin
(Denis Limouzin)
August 1, 2022, 1:13pm
1
Is it possible to configure the data that are saved and for how long it is saved to prevent dayabase to explose in size ?
Is it possible to purge database for old datas ?
Thanks from France (Bordeaux)
Welcome to the forum!
The integration that is responsible for your DB is recorder. Take a look here to get familiar with it:
You might want to read up some articles as well:
Note: This guide was written for an earlier version of Home Assistant (around 2021). Since then, changes have happened, but this guide hasn’t been updated (yet). Please be aware your Home Assistant version can be slightly different, and thus you need to adapt yourself the instructions from this guide.
Introduction
This is yet another guide on:
How to view the size of your database.
How to figure out which entities are using too much space.
And how to filter them out.
I’m running Home Assi…
Target audience: anyone who uses an installation on flash memory like a Raspberry Pi with an SD card or an SSD drive, or anyone who wishes to reduce the database size for better performance.
Flash memory can process a finite number of writes before it fails. As such it is desirable to limit frequency and size of the stored data.
Home Assistant stores a lot of data about events (example: light.office just turned on) and state changes (example: sun.sun changed to below_horizon). This allows it, …
