Hey guys, I wonder if you could help? I’m having problems sending IR signals from a Neo Coolcam IR Module. I am trying to create a script for the blaster which has been flashed with tasmota.
When I send an IR signal, I see the input on the console of the device which shows that it works, I can also send commands directly from the console using the sample send command below
*EDIT The crossed out section was a little misleading because the commands I was referring to there were entered directly into the blaster’s console (not through HA). When I run the script on HA I do not see the corresponding action on the blaster’s console. It does not fix the issue, but points to a communication issue between HA and the device. *
Irsend:{"Protocol":"RC6","Bits":20,"Data":"0x01010","DataLSB":"0x00808","Repeat":0}'
The problem is when I try to script this in home-assistant no signal gets sent. Here is the sample script I created for sending sending IR commands.
script:
philips:
sequence:
- service: mqtt.publish
topic: 'cmnd/tasmota_E866B3/IRsend'
payload: '{"Protocol":"RC6","Bits":20,"Data":"0x0100C","DataLSB":"0x00830","Repeat":0}'
Have I missed anything? Any help will be appreciated.
Here is one of my scripts - which works with a tasmota-ised IR blaster:
alias: LED Strip IR Remote - Dim Up
sequence:
payload: >-
{"Protocol":"NEC","Bits":32,"Data":"0x00F700FF","DataLSB":"0x00EF00FF","Repeat":0}
topic: cmnd/IRBridge01/IRsend
mode: single
Only other matter to consider is order of ‘cmnd/tasmota_E866B3/IRsend’ check it is not meant to be tasmota_E866B3/cmnd/IRsend.
thanks @rob1303 I tried copied your code but no signal gets sent. Here is a modified version of your script.
bedroom_tv:
sequence:
payload: >-
topic: cmnd/tasmota_E866B3/IRsend
mode: single
Regarding the topics, here is how i configured mine.
MQTT Group Topic 1 - cmnd/tasmotas/
MQTT Full Topic - cmnd/tasmota_E866B3/
Do I have to change the format?
Do you have other tasmota/mqtt devices set up and working correctly? ie) mqtt broker is all working.
Are you able to see the device in Configuration>Devices in HA?
If the blaster is in devices in HA are you able to execute the command from Developer tools>Services?
I found the issue. You pointed me in the right direction. It turned out to be a rookie mistake on my part. I did not specify the ip address of the mqtt broker when I configured the tastomta-ised blaster. in essence there was no way for it to communicate with HA.
Yes, I have a few other devices working already. I was so certain the problem was from the HA that I failed to look at the device configs.
Thanks for the assist.
