Configuring Plex Media Server
I’m running HA is docker and have been working on configuring plex but I can’t seem to get it working. Not even getting any errors or anything that might send me in the right direction.
I’ve setup the following in my config:
media_player:
  - platform: plex
       host: 192.168.0.200
       port: 32400
       token: M********************r
It’s formatted correctly in my configuration.yaml but nothing is found or nothing shows up on the web interface, no errors or anything either. I’m completely at a loss. Any help would be fantastic!
Thanks!
Token is wrong?
Token is right, checked it multiple times. Also don’t know if it’s related but emulated_hue isn’t working and neither is discovery, so I’m really not sure what is going on
And the home-assistant can reach port 32400 and the plex on: 192.168.0.200 ?
Yep, can reach it without issue
Did you make sure to set --net=host in your docker run?
Did you try Configurator https://www.home-assistant.io/components/media_player.plex/ ?
TOKEN (Optional): Only if authentication is required. Set to null (without quotes) otherwise.
This is the exact command I ran:
sudo docker run -d --name="home-assistant" -p 8123:8123 -v /config:/config -v /etc/localtime:/etc/localtime:ro homeassistant/raspberrypi3-homeassistant
That’s why discovery among other things is broken.
If you are not using --net=host, you are ONLY allowing communication over port 8123. Let it take over whatever ports it needs.
