I have installed succesfully Qubino Flush Dimmer 0-10V ZMNHVD1 to my Home Assistant (HA is a fresh install from this week). It shows up as three different thing:
light.qubino_zmnhvdx_flush_dimmer_010v_level_6_0 -> this controls brightness from 0-254
light.qubino_zmnhvdx_flush_dimmer_010v_step_size_6_6
switch.qubino_zmnhvdx_flush_dimmer_010v_switch_6_0
My ventilation fan can be controlled with voltages:
fan speed 4 = 5V = brightness 127 , level 5 = 6V brightness 153, level 6 = 7V = brightness 178, level 7 = 8V = brightness 203 and the maximum level 8 = 9.5V = brightness 250
At the moment HA shows the slider and I cannot control it exactly.
Is it possible to create a kind of selector where I can choose level from 4 to 8 and it will set dimmer to that level?
I tried the following in my configuration.yaml, but it didn’t work (I left out levels 5-7 to make it shorter):
input_select:
qubino:
options:
- 4
- 8
initial: 4
automation:
alias: Ventilation - 4
hide_entity: True
platform: state
entity_id: input_select.qubino
state: ’4’
service: light.turn_on
entity_id: light.qubino_zmnhvdx_flush_dimmer_010v_level_6_0
brightness: 103 -
alias: Ventilation - 8
hide_entity: True
platform: state
state: ’8’
brightness: 250
I’m really thankful if somebody can help me. I’m kind of out of ideas after trying different things for two days…
