Configuring rpi2-hassio to send mqtt messages to arduino uno-esp8266WIFI
So I got an rpi2-hassio and want to send messages to uno/8266WIFI shield with PubSub library.
And I followed this tutorial to get it connected to my network:
Im following this tutorial to send it mqtt messages:
Ivemanaged to send messages, now the issue is that there is no HIGH voltage across pins 3 and GND, or across pin 4 and GND when I send the commands. I see the commands log in the SM for 0 and 1, but I dont see the voltage across the pins.
My arduino code is:
#include <EEPROM.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Wire.h>
//#include <Adafruit_INA219.h>
#define in1 3 //We are not using PWM for this demo.
#define in2 4
// Connect to the WiFi
const char* ssid = "myssid";
const char* password = "mypwd";
IPAddress mqtt_server(192, 168, 1, 113);
WiFiClient espClient;
PubSubClient client(espClient);
const byte ledPin = 0; // Pin with LED on Adafruit Huzzah UNNECESSARY
void callback(char* topic, byte* payload, unsigned int length) {
 Serial.print("Message arrived [");
 Serial.print(topic);
 Serial.print("] ");
 for (int i=0;i<length;i++) {
  char receivedChar = (char)payload[i];
  Serial.print(receivedChar);
  if (receivedChar == '0')
  // ESP8266 Huzzah outputs are "reversed"
  raiseCurtain();
  digitalWrite(ledPin, HIGH);
  if (receivedChar == '1')
  lowerCurtain();
   digitalWrite(ledPin, LOW);
  Serial.println();
void reconnect() {
 // Loop until we're reconnected
 while (!client.connected()) {
 Serial.print("Attempting MQTT connection...");
 // Attempt to connect
 if (client.connect("ESP8266 Client")) {
  Serial.println("connected");
  // ... and subscribe to topic
  client.subscribe("curtainStatus");
 } else {
  Serial.print("failed, rc=");
  Serial.print(client.state());
  Serial.println(" try again in 5 seconds");
  // Wait 5 seconds before retrying
  delay(5000);
void setup(){
 Serial.begin(9600);
 client.setServer(mqtt_server, 1883);
 client.setCallback(callback);
 pinMode(ledPin, OUTPUT);//UNNECESSARY
 setupMotor();
void setupMotor(){
    //set the pins for output
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
 //set the pins low - this will keep the motor from moving.
 digitalWrite(in1, LOW);
 digitalWrite(in2, LOW);
void raiseCurtain() {
  //Spin Motor in one direction UP
  digitalWrite(in1, HIGH);
  delay(5000); //let it spin for about 10 seconds
void lowerCurtain() {
    //Spin Motor in the other direction DOWN
  digitalWrite(in2, HIGH);
  //Stop the motor
void loop(){
 if (!client.connected()) {
  reconnect();
 client.loop();
