Configuring Shelly for covers
Hi all. I have Shelly devices on my blinds and was trying to find a smooth way to integrate them into a single entity for each blind. Right now, each blind’s Shelly appears in HA as an “on” switch and an “off” switch. As it is now, it’s possible to toggle both inputs at the same time, which I’m sure can damage the motor.
Adicionally, using the switches with the entity card on lovelace causes a weird issue where the switch is turned off, but appears turned on in HA, and if I flip the switch back to off, no action is performed on the device itself (if it was already off) and the switch on the card will flip back on by itself. Is is possible it could be misreporting its state?
(in the image above, all blinds are stationary)
I have tried converting them from switch to cover but going this route ends up being the same as just using the switches as they are now, since they remain as separate entities.
Any ideas or help is appreciated. Thanks in advance!
