I’m new to home automation stuff and am trying to configure a simple relay for reading and setting IOs.
The device is sending data in the form of a string: A-R|1-5:0-2-2-3-2:0:2-0-0-0-0-0-0-0-0-0-0:1/80/30#255. I don’t know what all the values mean. All I’m interested in is the part :0: which is a 4 bit number, that tells which IO is set.
I can also send a string back with RLCTRL|1-3-0, which sets port 3 to 0.
I may be wrong but I don’t think what you are doing is valid. I couldn’t find anything in the docs about this component. “sensor relay” . What component are you trying to use? Maybe post the link.
“relay” is supposed to be just a name or id of some sort (as far as I understand). It works if you write just sensor. Important is that the platform is TCP.
I’ve managed to split the value and put it as a separate group.
Can someone help me, how can I put switches in this group and send a value to the sensor regarding the toggled switch?
This is the part of configuration dealing with the sensor:
