Configuring Template
I would like to configure a sensor that checks that all temperature sensors are working correctly.
I wrote this but the sensor value is always “unavailable” where am I wrong? Thank you
`- platform: template
sensors:
sensori_casa:
friendly_name: “Sensori casa”
value_template: >-
{% if states.sensor.rm_cucina_temperature != ‘unavailable’
and is_state(‘sensor.rm_sala_temperature’ != ‘unavailable’)
and is_state(‘sensor.rm_camera_temperature’ != ‘unavailable’)
ok
          {% else %}
            ko
          {% endif %}`
Please format the code correctly.
Use this syntax:
states('sensor.rm_cucina_temperature') != 'unavailable'
Really neat (in my opinion):
        value_template: >-
          {% if 'unavailable' in
                [states('sensor.rm_cucina_temperature'),
                 states('sensor.rm_sala_temperature'),
                 states('sensor.rm_camera_temperature')]
            ko
          {% else %}
           ok
          {% endif %}
Is there a way to tell if the value is different from a number? sometimes the sensor is in ‘unavailable’ state, other instances ‘none’
Thanks again
You can int cast it and if it returns 0 then it’s a string.
This will do that check on your list of sensors:
        value_template: >-
          {% if [states('sensor.rm_cucina_temperature'),
                |map('int')|select('eq',0)|list|length > 0
            ko
          {% else %}
            ok
          {% endif %}
It will apply the int filter to each element, keep only those that are zero, turn it into a list and calculate the length of that list. If there are any items left, one of your sensors is returning a string.
This relies on your rooms staying above 0°C of course.
