When I started in on setting up Home Assistant Yellow, I realized that mucking around with the files was not going to be recommended, if even reasonable to do. And I got about 90% of where I needed to go with the UI. But then I had to configure notifications for my flood sensors, and hit a roadblock.
My current configuration is as below, but it’s not obvious how to make this happen in HA Yellow (or indeed any supervised instance). I can’t find any UI for doing this, and there’s no obvious way to edit configuration.yaml. Yet this seems like such a foundational piece of functionality that surely there’s a reasonable way to do this. Does anyone have any insights on what I’m supposed to be doing here?
notify:
- name: XXX
platform: smtp
server: XXX
port: 465
username: XXX
password: XXX
encryption: tls
timeout: 30
sender: XXX
recipient:
- XXX
