Hope someone can help me work this out
SO I have a tuya zigbee based thermostat running on localtuya, all works but doesn’t show up as a climate entity and target temp for some reason is 10x the value so if I want to set to 15C I have to set to 150C etc.
So to fix half the problem I created a generic climate entity which works fine
Now my problem is how do I get the climate entity and thermostat to set temps on eachother? So if I set 15C on the climate entity I need it to set the thermostat to 150 (its a basic number entity), at the same time if I adjust the physical thermostat and it changes to 150 I then need the change to reflect on the climate entity so its also set to 15
Any ideas?
