Hello. I have just bought SkyConnect and I want to start a new instance of HA. I installed it on my Synology on VM using their HAOS ova image. Now I started from configuring Zigbee and Thread.
What I did so far:
- I changed a setting in
/config/hardware
to use multiprotocol on SkyConnect:
- Then I went to Addons and installed/configured:
- Silicon Labs Multiprotocol
device: >-
/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_e8ed77b32fb7ed119032955938a92db5-if00-port0
baudrate: "115200"
flow_control: true
autoflash_firmware: true
cpcd_trace: false
otbr_enable: true
otbr_log_level: notice
otbr_firewall: true
- Mosquitto Broker
logins:
- username: homeassistant
password: mypassword
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
- Zigbe2MQTT
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: homeassistant
keepalive: 60
reject_unauthorized: true
zigbee_herdsman_debug: false
serial:
port: tcp://core-silabs-multiprotocol:9999
adapter: ezsp
homeassistant: true
- I successfuly paired 3 devices and I can see them in
Z2M
, but I cannot inHome Assistant
. None of those 3 is visible in devices/entities. I tried to restart HA completely and it didn’t help. Do you have any ideas what’s going on? Rest of my configuration is default. It’s a fresh install and those steps I described were done at first.
I’m pretty experienced user of HA, because I have one instance without using SkyConnect
and Silicon Labs Multiprotocol
(there I have serial > port
set to device address "/dev/serial/by-id/something
) and it just works. Not sure if it is possible to use both Zigbee
and Thread
with SkyConnect
(but without ZHA
I checked logs of all the devices and nothing found. Everything is “successful”, “green” and “started”.
