I have a Tongou switch that is compatible with eWeLink. The Tongou switch requires a confirmation in the eWeLink app to turn it on and off, and it works perfectly there. However, in Home Assistant, it does not function properly because there is no confirmation option. When I try to turn it on, the switch automatically turns back off. I need a “yes” confirmation option in the homeassistant backend for it to work correctly.
Can you please assist?
Sounds like you need to use ‘optimistic’.
