I’ve encountered a showstopper of a problem with Home Assistant. When it’s running on my LAN, my digital VoIP phone on the same LAN malfunctions and won’t ring. I can’t run both of them at the same time. This is unfortunate!
I verified that if I use systemd to stop [email protected], the problem goes away and my phone rings normally. Start Home Assistant, and the phone won’t ring any more.
I’m stumped on how to try to diagnose this problem. I can’t find any mention of it in these forums or elsewhere. Any ideas??
The VoIP phone is a Linksys SPA-941 4-line digital phone, connecting to a SPA-9000 digital PBX on the same LAN. Incoming calls come in to the SPA-9000, which in turn transfers them to the appropriate line of the SPA-941. The SPA-9000 is still receiving the incoming call, and sends it to local voicemail correctly when the SPA-941 doesn’t answer. But the SPA-941 doesn’t ring if Home Assistant is running on the LAN. Probably the SPA-9000 PBX tries to transfer the call, but doesn’t succeed because something in Home Assistant is jumping in and intercepting or interfering?
The HA box, the PBX and the VoIP phone all have fixed IP addresses on the LAN, and are connected to a Netgear router by ethernet. There are no IP address conflicts. The phone uses SIP ports 5070-5073, which shouldn’t conflict with anything in Home Assistant to my knowledge.
After some experimentation I found a temporary solution, and another strange effect:
I moved the digital phone behind a secondary router on the LAN. At first I kept the secondary router in Bridge mode, so the digital phone still appeared with the same IP address on the primary LAN. I was hoping that if I disabled multicast pass-through it would block whatever Home Assistant is doing to the digital phone. The effect was that the digital phone would now ring, but with a 10-second delay! (delay only when HA is active)
So I put the secondary router in full NAT mode, and changed the digital phone to get a DHCP address on the secondary LAN behind the secondary router. That means that it can still see the primary LAN, but nothing on the primary LAN can see the digital phone. That works - the phone rings immediately for an incoming call, as it should. Isolating it on a secondary LAN is preventing the interference from Home Assistant. But no further insight into what that interference might be.
