Hi.
I have been a HA user for a long time, but for a long time I have just not had a lot of time doing stuff in my installation, and a lot of things has changed.
Today I tried to install the “Button State Card” in HACS, but it is not working.
In the GUI it is added as located in /hacsfiles/,all other old resources are in /community_plugin/
When I look at the yaml file, and the raw editor all three places are different. Can anyone tell me whats up?
Since you haven’t said, I will assume you are running the latest version of HA (113.x) and are using yaml mode for lovelace (or you wouldn’t be looking at the ui-lovelace.yaml)…
Since a few versions back all cards that are installed thru HACS are installed in the “/www/community/…” folder. Those are now referenced in the resources as “/hacsfiles/…”.
Also the resources no longer go in the ui-lovelace.yaml file. They now go in the configuration.yaml file under the “lovelace:” section.
Then you aren’t using yaml mode. So there’s no reason to be looking in the ui-lovelace.yaml file for anything. And they shouldn’t be in the raw lovelace configuration either.
All of you resources definitions (wherever they’re configured) aren’t correct for HACS installed files.
If it’s not already deprecated the “community_plugins/” endpoint will be deprecated soon. So you will want to switch those over to “hacsfiles/”.
Also as you can see from your screenshot above the “type: js” is being deprecated and will need to be switched to “type: module”.
@finity: I think you are confusing me with the OP
My remark was more to comment on your answer saying that the ressources declaration should be in the configuration.yaml.
I do have a configuration.yaml (but no ui-lovelace.yaml) and all my ressources are declared via the GUI.
