When I look at the description of templates, Template integration I see the label ‘required’ for sensor, binary_sensor, number, …
Does that mean that I cannot have a template in my configuration.yaml without a number map? Or is the system adding an empty number map when it is missing?
Or is the ‘required’ indication misleading and should it be something 'at least one of … ’
Thanks, Stefan
Each one is only required if you are defining that particular type of template entity.
e.g. if you are creating a template sensor, then the sensor label is required, the others are not. If you are defining a template number, then the number label is required, the others are not.
That would be a good suggestion. There are links at the bottom of the page for this.
