Confused by recent sensor states not passing through to automations causing 'Choose: No action executed'
I have a couple of automations that have been working for at least two years.
One is when a door opens or closes and its past sunset, turn on outside lights, leave on for two minutes and turn off. The second is to recieve a mobile notification that the door has opened or closed.
These have been working flawlessly for a couple of years and yesterday both stopped working when the door closes but works when the door opens.
The logs show the sensor reporting opening and closing and in my dashboard it is reporting the correct state and changes instantly when I stand by the door opening and closing it but in the automations when it gets to choose its reporting ‘Choose: No action executed’.
I have four other door sensors in the same door notification automation all working correctly, so I am really confused what the issue is or what else to check. I am using a conbee stick, all other zigbee devices are working correctly, the sensor logs seem correct, the HA and HA supervisor logs don’t show anything related. I’m not sure what else to look at to troubleshoot.
Any and all suggestions/advice are welcome.
This is the trace when closing the door
This is the trace when opening the door
Screenshot of the door sensor device page, currently reporting closed and in the logbook opening and closing.
