So I have 0.87 and can create an area. However it appears the only way to add devices to an area is via integrations UI. Most of my HASS items are not under any integration, in fact the only things I have under that is my iOS phones and my ChromeCast. All my lights are ISY and most of my sensor come from an Alarm panel.
It looks like the hass-cli has support for areas. This might be able to assign areas to entities that are not in an integration.
I will try this at some point but not sure when Iāll get time.
Well if it will only work with integrations, then it seems like it will have very little use for me. I suspect many people since I did not think my setup was that unique. I have 100s of entities but only 3 that are accessible by integrations.
True but this will force devās of odd components to start implementing their components in integrations if they want to use this functionality. In the long run this is good.
Right, but they havenāt been updated to work with integrations. All it takes is 1 developer wanting to have things only visible via the area they are in. BTW everyone wants this and people have been asking for this for the entire 3 years Iāve been here. It will happen, itāll just take time.
This seems very messed up to me. I thought integration were primarily for integrating other services which provided access to devices or information. I use yaml mode and I try not to use cloud based services except google assistant. I would like to use areas, but 90% of my devices are not supported with an āintegrationā. Has this changed? Are there plans to change it? Why cant we have the followingā¦
Is there a way to stop the areas appearing as panels on the UI? It doesnāt merge them with groups of the same name so I have duplicate panels scattered about.
I donāt think adding groups / light groups to Area Registry is possible yet, but if anyone knows how to do it Iād love the ability to add Light Groups (not just Groups) to the Area Registry.
Example:
I have some multi-globe fixtures using Hue connected globes (sorry, I canāt bring myself to call remote controlled globes āSmartā). I have these set up in Light Groups (not standard groups).
Example
light:
- platform: group
name: Living room ceiling
entities:
- light.livingroom_globe1
- light.livingroom_globe2
- light.livingroom_globe3
The above code shows the light group as light.living_room_ceiling, but this is not an integration obviously.
Iād like to be able to add it to the Living Room area register.
This is not so much for Lovelace, as I can manually configure lovelace, but for Voice Assistant setups.
Each entity that is integrated to an area in area registry shows automatically in Google Home in the correct room.
ie: Kitchen is a single Z-Wave Nano dimmer which shows as a Z-Wave integration ālight.kitchen_ceilingā. Google Home automatically picks this up as Kitchen Ceiling Light, located in the room Kitchen.
Does anyone know if this is available for light groups yet?
I completely forgot about that fuctionality. As a light group will show in the light domain, that would work perfectly.
I do hope one day it can be done via the Area Register so it can be done front end and also work with the new area permissions that are being worked on. I can use YAML and understand it, but I will be honest, I donāt enjoy YAML .
Thank you so much for reminding me about that option.
This method does disable the UI editing of devices, but I am impressed that the UI still shows which ones are enabled and disabled in a Read Only mode. Makes it much clearer than chasing through the YAML to work out what I had included and excluded
