msavazzi
(Massimo Savazzi)
January 6, 2025, 12:20pm
1
Team,
I’m very confused on the Tuya integrations.
I do see a Tuya original one ( Tuya - Home Assistant ), Local Tuya ( rospogrigio/localtuya: local handling for Tuya devices ) and Tuya Local ( make-all/tuya-local: Local support for Tuya devices in Home Assistant )
which one is the best one? or the real one?
Thank you
M
Hi, you will probably get different answers, for me, Tuya Local is top notch.
I used Local Tuya before, but made the switch when a needed device was only supported by Tuya Local.
tom_l
January 6, 2025, 12:45pm
3
Nothing about Tuya is “top notch”. Their wifi API is a garbage dump. Zigbee not so bad, just cheap and nasty.
haha, I stand corected. But here in South Africa, you don’t get too much options, so I’m talking my frame of reference
My 3 remaining tuya-wifi stuff died on me the last 2 weeks one after the other (pieces of sh… from the start), replacing with zigbee
dirkhaun
(Dirk Haun)
January 6, 2025, 4:29pm
6
Just came here to mention that my various WiFi Tuya devices are working just fine with the built-in (into HA) Tuya integration.
YMMV, as should be obvious from the above comments
