The new syntax is documented here: https://www.home-assistant.io/integrations/template/#switch
Converting your config above (which TBH looks kinda odd):
configuration.yaml:
template:
- switch:
- name: Garage Door 1
state: "{{ is_state_attr('binary_sensor.garage_1_input', 'sensor_state', 'off') }}"
turn_on:
service: switch.toggle
device_id: 24b0defe694c887c3b02fbf6cdb9b066
turn_off:
service: switch.turn_off
icon: >
{% if is_state('binary_sensor.garage_1_input', 'on') %}
mdi:garage
mdi:garage-open
- name: Garage Door 2
state: "{{ is_state_attr('binary_sensor.garage2_input', 'sensor_state', 'off') }}"
turn_on:
device_id: 07150b5772ce8095cb7392aa20b0426e
turn_off:
icon: >
{% if is_state('binary_sensor.garage2_input', 'on') %}
mdi:garage
mdi:garage-open
If you need more help see the pinned topic about this here: Deprecation of legacy template entities in 2025.12
