seaes
(sander advokaat)
February 4, 2021, 8:32am
1
I found on
the following:
Home Assistant uses database to store events and parametersis for history and tracking. The default database used is Sqlite …
To work with SQLite database manually from the command-line, you will need an installation of sqlite3 …
My questions:
are sqlite and sqlite3 2 different things?
which is standard in the Image (installation)?
and which of them is standard on ‘Home Assistant Blue’?
Thanks in advance,
Sander
No, sqlite is the program and sqlite3 is version 3 of the sqlite program.
Mutt
(Muttley)
February 4, 2021, 9:26am
3
And
seaes:
Is merely one possible hardware platform that you can run HA on
m0wlheld
(Christoph Dahlen)
February 4, 2021, 10:39am
4
seaes:
Home Assistant Blue is just an HA appliance running Home Assistant OS, so I assume that sqlite3 is used by default. As with every instance of Home Assistant, you can choose alternative database backends, like MariaDB.
