Connect Brel hub hub DD-7002B
Hi all,
I just received my Brel blinds with the Brel hub DD-7002B.
Thought it would be easy to connect it to home assistant, but in the post I found on this forum I would need to get the API key. This could be done by using the app and press 5 times on ‘about’.
But I can not find this in the app! Can anyone point me in the right direction?
I also tried the Connector app to connect to the hub, but somehow it doesn’t connect. It won’t find the hub in pairing mode.
Hope someone can help!
Kind regards
I don’t know if you finally find how to get your token but you need to go on the account page (the last on the right) and then tap 5 times on the empty space near your avatar picture :
@Eltjo_de_Waard
Did you succeed with the integration in Home Assistant? I’m considering to buy blinds with a Brel motor too.
Hi, yes it worked without any problems!
