Connect custom device to home assistant
Hi everyone.
I am a newbie using the home assistant.
This is what I looking for:
I have developed a control panel inside a NodeMCU plus a touch screen.
I want to integrate the panel to the home assistant but I don’t know how what could be the best way to do it.
I searched through the integrations without luck.
The idea is to communicate the panel with home-assistant through MQTT. Basically the panel has a state in the form of a JSON ARRAY, each entry will be a home assistant entity.
You should try the API over HTTP.
By the way, no “the” necessary. :slight_smile:
