Connect Daikin Cloud NA to Home Assistant
I’ve attached the entity list for you and the graph from the thermostat integration.
It runs off the P1 P2 com or the S1 which unfortunately just shows functionality on the DKN software. So far, only the Daikin D-checker software can show the breakdown of everything going on in the system but only with P1 P2 capable units.
You would probably have to get into Modbus to get that out but I’m not sure. I ended up just getting a zwave disconnect with power monitoring for the outdoor unit.
The DKN is named “Murata Manufacturing Co Ltd” on the clients list
Thank you! I assume you can also control heating if the unit supports it?
I was able to get the gpulido/homeassistant-airzone HACS integration to work with my new Daikin unit with the AZAI6WSCDKC module.
It works pretty well with local control. The github hasn’t been updated in about a year, not a lot of support but as long as it continues to work, I’m happy.
I do see that the DKN Plus NA App has more information than the integration (or even the API via the local IP) provides. One of the missing items is the external temperature.
I’m just wondering if anyone has been able to get the AZAI6WSDKB to integrate with HA? So far not impressed, especially considering the $$.
I too have one of these (AZAI6WSDKB), and cannot add it to HA. Working in the DKN Cloud NA app.
My supplier was kind enough to swap the B unit out for a C. No problem with the C.
Hi thank you so much!!!
Works amazing
1 problem after adding my first IP
The next comes in as no entity
Hi there,
After purchasing the wrong Airzone unit at first, I went and purchased the AZAI6WSPDKC based on this thread. I’ve turned on “localapi” in the settings in the DKN Cloud NA app, however I can’t seem to get this unit connected to home assistant. I’ve tried the Airzone and Daikin Cloud plugins to no avail. The Airzone plug-in does not appear to be working nicely with the current version of home assistant.
Can you confirm which plug-in you’re using with this module?
Thank you!
